High Idle After TPS Adjustment
Old Feb 17, 2005 | 12:56 PM
james93gxe's Avatar
I just finished adjusting my TPS according to the Haynes Manual and I start the car and it idles at about 1600. Did I do something wrong or does the PCM need a few drive cycles to compensate?
Old Feb 17, 2005 | 01:28 PM
avmaldo's Avatar
should be at 1k ohms closed throttle.
If it already is, your aac valve may need cleaning, replacement or adjustment.
Old Feb 17, 2005 | 02:13 PM
james93gxe's Avatar
Thanks for the reply. I checked it before adjusting and it was like 850 ohms closed and 7.5k ohms at WOT. I'll check it again to see if anything has changed. BTW when I said idle, I meant in park or neutral warmed up. Its between 800 and 900 in "D" or "R".
Old Feb 17, 2005 | 03:04 PM
james93gxe's Avatar
Well, I drove it to the store and back and the computer seems to be sorting things out. I'll keep an eye on things, but I think there isn't a problem. I'll check for carbon deposits in the IACV also.
Old Feb 18, 2005 | 04:16 AM
Wiking's Avatar
TPS is a potentiometer that wears as any; actually you're measuring the soot on the pot surface; this soot comes and goes like on trips from here to there an' back.
TPS Can be cleaned likewise as radio pots: with electronics cleaner. To access, fabricate a hole in the upper corner, then spray in cleaner while rotating the throttle axle. Close hole with silicon.
see inside: http://www.cardomain.com/memberpage/748507/6
-93 VG30E Automatic: After studying, I came to conlusion [pls give input if error] that TPS is used by ECU only during warmup. After warmup ECU uses only MAF & O2. TCU instead uses TPS always and calculates pedal pressing speed for gear change ctrl. Zero pos sw is used by both, the wide angle sw is not used at all.
Old Feb 18, 2005 | 05:04 AM
LvR's Avatar
LvR
Wiking - I dont have a dedicated manual for our specific South African ECU/electronics, but our cars dont have O2 sensors .......... in our case where no O2 sensor is present the TPS could (?!) be used I suppose.......
Old Feb 18, 2005 | 06:23 AM
Wiking's Avatar
I suppose so. The O2 is 'plain stupidity'; the whole computer environment is... Newer maxes have three O2... I am pretty sure the same output could have been done with lots fewer sensors.
These old cars have some ten computers, some newest get now near 100. What will they be after 10yrs? junk.
I guess there are many versions of ECU programs, are they on EPROM or just plain jumpers? at least nissan document people seem confuzeus. I suppose that there is no such info [ECU versions], all off mainstream were ? done in dark corner by sub/sub/sub manufacturers... Maybe somebody here has real intel inside info after my worm count...
Btw. It would be nice to know that 'jumper' for non O2, just in case...
Old Feb 18, 2005 | 07:14 AM
LvR's Avatar
LvR
Indeed! .
tarun900
19
Dec 20, 2021 06:57 PM
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
