Fuel pump fuse!!!!
Old Feb 19, 2005 | 06:37 AM
nismo3366's Avatar
Fuel pump fuse!!!!
Hey everyone...just had a quick question. i tried a couple weeks ago to change my fuel filter..i took out the fuse that the panel told me was the right one...but my car stayed on after 5 mins...so i never did it...so i has wondering if someone could tell me the right one...like for example...right side 3rd down from the top....something like that so i know....thanks for all the help
Old Feb 19, 2005 | 07:32 AM
Wiking's Avatar
On oldies u never now how they are possibly rewired.
a. Take fuse off one by one and listen after u put the ign on.
b. Take batt out and loosen the hose and let the pressure leak off.
c. lift up the rear seat and go after pump wire connector there, then run the engine until gas has gone...
Old Feb 19, 2005 | 11:18 AM
maximagxe90's Avatar
Hi,
your fuel pump fuse should be on the right hand, the fuse is toward the bottom,
look on the panel cover it should tell you where it is located,
it will say fuel pump,
Old Feb 19, 2005 | 03:13 PM
nismo3366's Avatar
i took out the one that the panel told me too and it wasent the right one...i guess ill keep trying or just take off the hoses with the presure and hope not too much comes out lol..thanks guys
Old Feb 19, 2005 | 08:38 PM
hi,
you can't remove your hose because your fuel system is under pressure, so you have to some way off getting the fuel pump remove in order to depressure your fuel system to change your filter,
do you have a digi cam,
if you do take a picture of the panel cover so we can show you where the fuel pump fuse is,
leatherneck
Sep 30, 2015 09:16 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
