Corner light installation help
Old Feb 19, 2005 | 03:18 PM
Mattster's Avatar
I need some help on removing the corner lights so i can put in the clear ones i got at the junkyard for like $10. After i removed the top screw they just kindof popped out. But on my maxima i have to remove top screw but i dont know how to get the the lower screw to remove it. Any help on how to remove it would be appreciated.
Other spoils from the Junkyard:
Working Clock
Hood
Red Grille
White Hood (getting painted red soon)
Hood struts that held the white hood up but don't seem to hold my red hood up for more that 5 seconds.
Another question, about how much paint would I need to paint the hood? And where abouts would I purchase the Red maxima paint?
If anyone needs stuff from a White 1990 GXE it has just about everything. Pretty nice condition just no tires.
Old Feb 19, 2005 | 03:21 PM
HTPerformance's Avatar
hmm you push the ball/knuckle into the headlight, and then screw in the top screw.
Old Feb 19, 2005 | 03:45 PM
tripleGmax's Avatar
yeah dont unscrew it, just pull that sob out. i remember when i first saw it i thought you had to unscrew it, but it pulls right outta there.
Old Feb 19, 2005 | 04:13 PM
Mattster's Avatar
I got them out but the wiring harness is stuck on the corner light. What is the bulb size of that tiny light? I couldnt get the harness off either side.
Old Feb 19, 2005 | 04:15 PM
tripleGmax's Avatar
twist the thing around, it should then pull out.
if you need bulbs, just go to wherever you get bulbs(autozone) use their book or electronic book and look it up. take in the bulb with you.
Old Feb 19, 2005 | 08:50 PM
disgruntled's Avatar
the larger bulb is 1157, the smaller bulb is 94
Old Feb 20, 2005 | 08:44 AM
MaximaBalla's Avatar
The smaller bulb is 194, but I think that's what disgruntled meant.
Old Feb 20, 2005 | 12:24 PM
lalo's Avatar
I cant belive this is a post, OMG.
you cant remove the corner lights?? Harness/Bulb?? DUDE....
I would understand not knowing what type of bulb but dude, you cant remove the bulbs???
http://www.autozone.com/servlet/UiBr...3d801f5325.jsp
Edit: Speachless......
Old Feb 20, 2005 | 07:24 PM
Thanks for looking out MaximaBalla, 194 was what I meant, got a lil too eager hehehehe...
Old Feb 20, 2005 | 08:10 PM
ozzombie13's Avatar
I will eat your children
do we seriously need a post about corner lense replacement??? if you cant fighre it out take it to your local body shop im sure they would love to help by charging you alot to pop the lense out for you .. o and make sure you pull it forward so as to not break the little clip things on the back of the lense
Old Feb 21, 2005 | 10:01 AM
Mattster's Avatar
I dont remember anywhere stating i couldnt remove bulbs. But to keep flamers away i was just confused about whether the corner lense had 2 screws to get it out or 1 and a ball/knuckle joint. whatever, thanks for the bulb sizes.
Old Feb 21, 2005 | 10:09 AM
tripleGmax's Avatar
well you did say you couldnt get the harness of the corner light, and the harness is connected to the bulb......so can you see why people would think you couldnt remove a bulb?
anyway, next time you got a hard job to do like removing a light, you should probably take it in to a mechanic. They are professionals.
Old Feb 21, 2005 | 11:39 AM
Scope's Avatar
Im izz sexay
I broke my clip thingy on my drivers side. I said screw it. To tell you the truth It doesn't even pop out. What's it there for?
Old Feb 21, 2005 | 11:47 AM
Kikcaffine's Avatar
dude you all need to calm down, its an honest question someone would ask, jeez!
Old Feb 21, 2005 | 12:40 PM
tripleGmax's Avatar
the knuckle clip thingy is to hold it in more secure i believe. im not mad its all good kikcaffine. btw do you have any pics of your ride? i see you got bunch of stuff done to it.
MaximaDrvr
Aug 19, 2015 08:20 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
kirkhilles
Aug 8, 2015 10:53 AM
MikesChevelle
Aug 6, 2015 11:36 AM
