Axle advice
Old Feb 20, 2005 | 05:34 PM
Agavehound's Avatar
Axle advice
I'll be replacing my axles soon and was wondering if there was anything special to watch out for or special tools required. Here's what I've got:
93GXE auto/abs. Any suggestions on where to pick up the axles and seals?
Chuck
Old Feb 20, 2005 | 06:49 PM
rowen93se's Avatar
axles at junkyard...seals at dealership
Old Feb 20, 2005 | 07:04 PM
Cliff Clavin's Avatar
Way out West
four letters...
N A P A
Old Feb 20, 2005 | 07:10 PM
Agavehound's Avatar
Should I expect any problems with removal or installation of the axles?
Chuck
Old Feb 22, 2005 | 12:17 PM
-shock211-'s Avatar
Chuck
the only pita area is the passenger side driveshaft bracket. it's on the back of the engine and the bearing housing seems to always be super seized in there. once you do get it out make sure to anti seize the new bearing housing.
Old May 7, 2005 | 01:28 PM
Agavehound's Avatar
Been a while since I replaced the axles and now I've got a leak from the dang seal I didn't replace. I tried to get it out today but the dang thing won't come out. Any advice on how to get the seal out?
Old May 8, 2005 | 05:36 AM
Agavehound's Avatar
Is there a special tool required to remove the old seal? Anyone?
Old May 8, 2005 | 06:50 AM
nelledge's Avatar
"I'm just sayin'..."
You can buy a generic seal remover. Usually just a thick hook you put through the middle of the seal, grab the inside wall of said seal, and pull. I'm sure you can find something around your garage that will do the same thing. If you have a deep socket that will fit snugly in the seal, you can use that as well. Place it on the end of an extension, put it into the seal about an inch, put a small amount of lateral pressure on the extension as you pull it out. This method has worked for me in the past. Just remember to exercise caution.
Old May 8, 2005 | 05:30 PM
tripleGmax's Avatar
i think a couple people who have replaced them recently have screwed their abs up by messing up the little magnets...be careful there.
Old May 9, 2005 | 12:03 AM
VEvolution's Avatar
I miss my VE
i get a slight "rusty" screeching sound off the line(as I start moving) coming from the front passenger wheel area, but goes away after the car starts rolling. sounds like metal doors being opened on an old rusty ship. could this be an axle problem? thx
Old May 9, 2005 | 05:01 AM
nelledge's Avatar
I would venture to say it sounds more like a brake problem. How do your brakes look?
Old May 9, 2005 | 06:30 AM
internetautomar's Avatar
mod or sell?
bearing shot on a pulley maybe?
Old May 10, 2005 | 12:51 PM
VEvolution's Avatar
I miss my VE
lol, i have about a thousandth of an inch left on each pad and the rear driver side caliper stopped working years ago
Old May 10, 2005 | 04:24 PM
nelledge's Avatar
You're going to be sorry if you don't replace those pads and get that caliper fixed. Bare minimum: Even if you have no moolah, do a quick pad slap in the front. Money no issue? Fix the blasted things before you empty your wallet completely!
Old May 10, 2005 | 04:31 PM
Pervis Anathema's Avatar
Please don't drive your car again until you properly repair your brakes. Irresponsible people like you are what causes fatal traffic accidents. If you don't care about your own safety, at least consider those around you. Your location says that you are in D.C. May I suggest the Metro or the VRE to get around?
Old May 10, 2005 | 04:45 PM
VEvolution's Avatar
I miss my VE
i actually travel alot for buisness, so my locations may vary, and my 4DSC is what gets me around. but anyway, i thought normally when brakes are on their way out, they just dont feel as crisp as they use to be, thats all. them working great one second and then completely stopping, especially up to a point where somebody is in grave danger, is very hard to believe. but yeah, i'll get right on it sir. i heard they have asbestos, gotta watch out
Old Nov 15, 2005 | 11:07 AM
Site's Avatar
Need Snap Ring (Circlip) for Driver's Side
Hey all, I would put this in a new post, but I don't have the necessary post count to do it yet, and I'm not into meaningless posts.
I recently replaced the clutch in my 93 SE, and in the process, I lost the circlip (snap ring) to the driver's side cv axle. I can't find these anywhere as a separate item. Does someone have an extra that you wouldn't mind mailing to me? I'll pay you for shipping, and a couple bucks for the circlip, too.
Thanks!
Mike
Old Nov 15, 2005 | 06:32 PM
mtbendo's Avatar
Originally Posted by Cliff Clavin
four letters...
N A P A
Does NAPA usually stock seals? I've already pulled my axles but haven't found anyone other than the dealership that has the seals.
Old Nov 15, 2005 | 06:51 PM
Greeny's Avatar
¯\(°_o)/¯
Thanks!
Mike
Looking fur this..
Old Nov 16, 2005 | 05:36 AM
Site's Avatar
That's the one, MyGreenMax94. If it's extra, I'll be more than glad to make arrangements to buy it from you.
Originally Posted by MyGreenMax94
Looking fur this..
Old Nov 16, 2005 | 05:44 AM
Greeny's Avatar
¯\(°_o)/¯
Just email me your address and i will mail it to you...free.
My email... wayne_ecps@yahoo.com
Old Nov 22, 2005 | 05:12 AM
Site's Avatar
Got the part yesterday - thanks MyGreenMax94, you're the best!
Old Nov 22, 2005 | 05:44 PM
Alex_V
If I knew you were in columbus I would have given you one. Or you can go to picknpull, they always have 2-4 max's in the yard.btw i have a parts car sitting at my aunts house off of carl road, if you want any parts i may have them. just pm me
~Alex
Old Nov 22, 2005 | 06:03 PM
CyMax's Avatar
Differential seals?? Looking a tthe FSM they are useing some puller type device to get it out!? This is the one someone suggests can be pulled out rather easily? Anyone have a part # for it?? Nissan dealership in backyard and I'm putting my new axels in tommrow.
Mahmuth
Aug 16, 2024 08:23 PM
gigabyte
Jan 6, 2017 06:05 PM
Pnjboyzz
Nov 16, 2015 12:27 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
RealityCheck
Oct 2, 2015 06:34 PM
