Need some tune up advice
Old Feb 20, 2005 | 07:38 PM
disgruntled's Avatar
I currently have a very limited budget, under 1 grand, and I want to do a tune up for my car + worn clutch replace ment if budget allows.
Things done so far:
Control arm replacement
Clear corners
Distributor cap replacement
Oil changed
Things need to be done:
Timing belt replacement
Water pump
(Thermostat) maybe???
Clutch replacement (if determined to be worn)
Complete coolant flush and fill
So, can someone please enlighten me on the prices for parts to do the things listed above?
Also, I'm trying to cut down on labor cost and will attempt to replace the timing belt, and water pump (and possibly the thermostat) myself. Keep in mind that I have replaced my control arm and cen figure my way out with the right tools in hand, is this job feasible? If it is, is there any got cha's I should look out for? Is there any instruction that you guys can link me to? Thanks in advance.
Old Feb 20, 2005 | 08:07 PM
ozzombie13's Avatar
I will eat your children
talk to internetautomar hes the org parts guy just find a thred with him in it and click his link
Old Feb 20, 2005 | 08:17 PM
internetautomar's Avatar
mod or sell?
he got the arm from me already.
Old Feb 20, 2005 | 08:24 PM
ozzombie13's Avatar
i didnt know, i just knew you had alot of good prices.
Old Feb 20, 2005 | 08:34 PM
Harvs94max's Avatar
internetautomart has very good prices other wise most of the parts can be found at local parts stores
as far as instructions go try and pick up a chiltons manual or haynes or go on autozone.com they have an online repair manual that is great
Old Feb 21, 2005 | 06:00 AM
mod or sell?
I apologize if I sounded rude.
Old Feb 21, 2005 | 08:14 AM
any estimated figures? and what is the average time spent on replacing timing belt, water pump, and while I'm at it, maybe a thermostat as well?
Old Feb 21, 2005 | 03:41 PM
lalo's Avatar
If you replace the timing belt, you might as well replace the water pump, and if you replace the water pump might as well do the Tstat.
kind of a chiken or the egg thing
Old Feb 22, 2005 | 05:45 AM
I'm almost ready to place an order with internetautomart, just don't know which is better, a 170 degrees thermostat or the 180 degrees? Which one is the OEM spec?
Old Feb 22, 2005 | 06:56 AM
Wiking's Avatar
Depends where u live, how u use your car. Spark plugs, ign timing etc go in concert... Engine should never overheat.
Me, coldie, wants hotter engine 180 degrees or more. I have no danger of overheating my engine.
Old Feb 22, 2005 | 09:16 AM
DennisMik's Avatar
The FSM says 180 degree, but I like hotter ones myself if I can find em.
Old Feb 22, 2005 | 03:02 PM
that settles that, now about the clutch,
which brand is better? (These are sold by internetautomart mind you)
Autospeciality
Sachs
Exedy
which is considered an OEM replacement, maybe slight upgrade, I'm on a budget.
Old Feb 22, 2005 | 04:42 PM
mod or sell?
The Exedy stage 1 is a performance upgrade
the Daikin is a stock replacement as are the Autospeciality and the Sachs (which is OE on german cars)
Mahmuth
Aug 16, 2024 08:23 PM
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Pnjboyzz
Nov 16, 2015 12:27 PM
Socalstillen
Sep 26, 2015 12:01 PM
