ELECTRONIX Questions : 3rd GEN
Old May 1, 2001 | 05:01 PM
roadiusmaximus's Avatar
What do i do about fitsy windows and door locks? the driver side door only goes down occasionaly upon pressing the button.
And the door locks only work every now and then. Are these worn relay switches?
The trunk popper button, does nothing now? Anyone have any experience? Suggestions?
And lastly, the climate control (digital), does not display anymore, i think it may be shorted.
These problems are all unrelated as they occured at different times and situations.
Exchange info for info, thanks millions
John
trywndw1@hotmail.com
IM: xpandermedway
Old May 1, 2001 | 05:15 PM
hoey's Avatar
i have this problem too...
it just started not to work every so often...
kind of started when the weather became hot...
and when its cooler it works... i dunno if that has anything to do iwth it...
i think it might be a fuse or something, but im not sure and havent checked...
Old May 1, 2001 | 05:26 PM
Blu Max's Avatar
Check the metal contacts make sure they are clean( like Distributor caps)
Old May 1, 2001 | 07:05 PM
eric93SE's Avatar
I dont have digital climate control.
But I had posted on this in the past.
when I got my car the window wouldnt open on the driver side. so I removed the control in the driver door and was able to figure out that one of the relays burnt out and also that the rubber pad contacts nolonger conducted properly. If you were to purchase a new control it goes for ~100 (from courtesy nissan). I replaced the relay (the contacts were burnt) it is difficult to figure which one is bad so if you know how to remove them just replace both ~$5 a piece. When it comes to the rubber pad contacts you can repaint new contacts. I bought the chemical through MCM Electronics ~$30 I think the brand was chemTech or something.
stevesmax
Dec 17, 2020 11:57 AM
carlosvq30
Aug 17, 2015 11:32 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
