VG ticking? studdering issues
Old Feb 23, 2005 | 05:41 AM
Konamonkey02's Avatar
my VG has a couple of issues. First, there is a ticking noise. it is coming from somewhere in the engine it sounds like. The ticking can be heard at any speed. Any ideas? also it has a studdering problem once the car warms up. When the engine is cold, it doesnt seem to studder, and when its warm, it doesnt studder after 3000rpm, and there are like 2 slight hicups after 3000. any help would be appricated?
Old Feb 23, 2005 | 07:29 AM
Wiking's Avatar
Valve lifters - replace. Smbdy smwre said smtg of gunk cleaner - hlps...
O2 sensor? Check http://www.cardomain.com/memberpage/748507/9
2 hicups - drink 2 cokes
Old Feb 23, 2005 | 08:17 AM
bhunter's Avatar
I think the VG guys will say broken exhaust studs.
Old Feb 23, 2005 | 08:58 AM
tripleGmax's Avatar
i concur with bhunter. if it sorta goes away when car is warmed up and it gets faster with higher rpms its most likely broken studs.
maybe seafoam your engine too.
Old Feb 23, 2005 | 09:21 AM
snoozebar's Avatar
I had the same problem with my 93 GXE and it was caused by a bad spark plug wire. Look at the engine at night and check for arcing at the end of the spark plug wire nearest the plug.
Old Feb 23, 2005 | 01:41 PM
wow, thank you so much for all the replys, esp. the last one. I figured replaceing wires and plugs was routine maintaniance anyways so i did that first, and as soon and i replaced the wires, all problems went away. and with the new plugs it feels much smoother. THANKS SO MUCH!
Old Feb 23, 2005 | 03:33 PM
goon9's Avatar
I got the same problem and i'm sure it's a stud issue.
Old Feb 23, 2005 | 10:24 PM
Wiking's Avatar
Some first write here, some open first their hood. Most do ALL maintenance on time and need either...
I suggest u will not leave your halfway maintenance to that.
Mar 12, 2020 12:06 AM
conansriver
Nov 18, 2015 02:46 PM
ColdCananda
Sep 20, 2015 10:45 PM
BrandonCause
Sep 14, 2015 10:41 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
