TB gasket leak?
Old Feb 26, 2005 | 08:51 AM
blacks92seAuto
TB gasket leak?
I have always had a slight whistle at various points of acceleration....I always thought it was just my CAI, I was looking at my TB other day, and you can see in the corner part of the gasket is missing....when I did my motor swap, my mechanic friend swapped my intake manifolds, and TB....maybe the gasket tore a lil there but it was still good to use? i know he never asked me to get a new gasket. Should I put a new gasket on? is there anyway I can check to see if it is even leaking there ? someone told me earlier to spray some starting fluid where i think the leak is.....and if the motor started running differently then there is a leak....
Old Feb 26, 2005 | 10:08 AM
Matt93SE's Avatar
STFU n00b!
Nah, that's the CAI.. mine does it too..
When I bored out my TB, it changed quite a bit, and when I installed my TB spacer, it changed again.
What you can do is get some soapy water (instead of starting fluid), and spray it on the TB where the gasket is.. if you see the bubbles getting sucked into the crack, then there's obviously a leak..
but I'm 99% sure it's just the normal sound they make when you have a CAI installed.
Old Feb 26, 2005 | 10:16 AM
blacks92seAuto
thanks, gonna go try it out right now
Old Feb 26, 2005 | 10:48 AM
blacks92seAuto
thanks for the tip, looks like i have no leak....but i did notice a crap load of dirt on the under side of my K&N filter, man I need new plastic shields underneath, dont know how all that dirt gets sucked into the fender.
Old Feb 26, 2005 | 10:58 AM
Matt93SE's Avatar
STFU n00b!
water splashes up there and all kinds of other stuff... cars kick up a lot of dirt just above the road surface that you can't see... that's part of the reason I took off the bottom tube on my CAI and just run a WAI.. the filter stays much cleaner up there.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
knight_yyz
Nov 1, 2015 01:34 PM
Gingerheadman
Oct 1, 2015 05:11 PM
