help with antenna.....again
Old Feb 26, 2005 | 10:30 AM
whitemax28's Avatar
I have an OEM look-alike aftermarket antenna and wanted to check which color wires do I connect from the stereo to the antenna again??? On the antenna the wires are red, white, and black for the ground.
Old Feb 26, 2005 | 10:52 PM
whitemax28's Avatar
yoooooooooooo any advice??????????????
Old Feb 26, 2005 | 11:16 PM
Michael's Avatar
Back in a 3rd Gen.
Well I took these pics a couple of years ago. Hopefully they will help you out. I put an anftermarket antenna in and this is how I hooked it up.
pic 1
Pic 2
I wish I could help you more but I dont remember the exact steps I took but I believe the pics will help you determine which wires you need to use.
Old Feb 27, 2005 | 11:45 PM
Vadim-93GXE
What happens when an antenna gets stuck out? Normally, it slides in/out when I put the radio on/off, but recently it's just stuck up there. New antenna?
Old Feb 28, 2005 | 08:24 AM
Michael's Avatar
Back in a 3rd Gen.
antenna mast cable has broken. Read the article on 4dsc to see how to change the mast.
Old Feb 28, 2005 | 08:58 AM
greggie195's Avatar
I also have an antenna problem, amongst other things with this money pit of a car. The antenna only goes up when the car is on, but not started. When it's started it only sometimes goes up or only goes up a few inches. Anyone have this annoyance?
Old Feb 28, 2005 | 01:21 PM
Vadim-93GXE
Yeah, I did before mine just stopped moving one day. Im geussing you have the same problem as me, or the "pre" symptoms of it.
Thanks awsm66, I'll check it out.
