Plz plzz help me Heating guage
Old Feb 26, 2005 | 02:32 PM
nomi640's Avatar
I have Maxima 93 my heating guages stop working
and there is some heating problem too some time its working fine some time not can some one plz help me for this
Old Feb 26, 2005 | 05:44 PM
internetautomar's Avatar
mod or sell?
could be the sensor.
Old Feb 26, 2005 | 11:23 PM
nomi640's Avatar
where is the sensor
some time its workes for 2 or 3 sec then goes down can u tell me how i can fix that sensor coz its also effecting heating
thanks
Old Feb 27, 2005 | 05:47 AM
mod or sell?
not sure where the sensor is.
we also need to know which motor you have
Old Feb 27, 2005 | 10:26 AM
nomi640's Avatar
Its VG30E type engine
now u can tell me where is that sensor
Hectic's Avatar
the sensor isn't affecting the heating, the sensor is actually doing its job telling you that there's no water to sense which means you have air in your cooling system most likely. fart your cooling system.
Old Feb 27, 2005 | 10:29 AM
nomi640's Avatar
My heating guages is not working too i want to fixed that too and also tell me how i can remove air from my air cooling system
Old Feb 27, 2005 | 11:01 AM
mod or sell?
look in the stickies, I'm pretty sure the bleeding procedure is there.
that is a commom cause of lack of heat.
I don't know where the temp sensor is for sure, but hopefully someone else will pop up and tell you where it is.
Old Feb 28, 2005 | 09:20 AM
nomi640's Avatar
Can some 1 plz tell m where is the sensor for heating guages
Old Feb 28, 2005 | 12:02 PM
maxitech's Avatar
you could also replace your thermostat. the part is only like 11 bucks
Old Feb 28, 2005 | 12:36 PM
nomi640's Avatar
can u tell me location of thermostat??
Old Feb 28, 2005 | 01:43 PM
GreenMaxVE's Avatar
Check out www.autozone.com for locations. Click on repair info, then vehicle repair guides.
Old Feb 28, 2005 | 01:45 PM
maxitech's Avatar
towards the left side of the engine, below the distributor cap. the cruise control assembly is also in theat general area. you remove the housing and replace the thermostat. you will also need a gasket.
Old Mar 1, 2005 | 12:00 AM
nomi640's Avatar
Thanks for ur help guys
tarun900
19
Dec 20, 2021 06:57 PM
Fbana41
Aug 29, 2016 12:18 PM
captchaos
Mar 15, 2016 12:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
