idle a little rough, chugging, steering vibrate at low speed
Old Mar 2, 2005 | 06:57 AM
orelt's Avatar
HI guys,
I need help on my maxima gxe 1992. the idle is little bit rough, the muffler is chugging, and when you speed at 40-60 km/hr city driving, steering is vibrating. doesnt stall, no error code on the ecu, consumed more gas that normal. checked the coil and high voltage wire were ok. i live in the north east, so it is cold here.
Appreciate all the help you can give.
thnks a lot.
orelt
Old Mar 2, 2005 | 07:44 AM
Wiking's Avatar
Check sensors, especially Knock Sensor. Replace plugs, wires, cap, filters.
how: http://www.cardomain.com/memberpage/748507/9
Clean ALL connectors. how: http://www.cardomain.com/memberpage/748507/14
check www.autozone.com for online manual
Old Mar 2, 2005 | 08:28 AM
internetautomar's Avatar
mod or sell?
my money is on a miss from a bad injector.
with the car running unplug the spark plug wires one at a time, and find which one causes NO change in the cars idle.
that one would be the dead cylinder.
measure that injectors resistance, it should be between 10-14 ohms. any other resistance is futile. you'll need a new injector.
I sell injectors along with way too much other stuff.
Old Mar 2, 2005 | 02:23 PM
Ivan Yulaev's Avatar
Crap, will have to check KS. I have all the same symptoms!
Wasn't there a recall on the knock sensors?
Old Mar 3, 2005 | 08:16 AM
orelt's Avatar
thnks for the info, Wiking and internetautomar. i wish i could do the checking rite now, but the weather here in montreal is cold (-14 C). i can only work outside. I hope spring come early. i already tried what internetautomar was advising with the 3 front spark plug wires, and it seems theyre ok. if the weather get a little better, i will try the other 3. is there a technic to remove the injectors connectors, it seems that there is a lock before you can pull it. i am not sure if want to spend to much money on the car, the body and wheel well were showing rust and holes.
thanks again,
orelt
Old Mar 3, 2005 | 08:22 AM
Wiking's Avatar
KS bypass is 30 sec job. Well, with that weather its 61 sec...
KS cannot be felt nowhere but in the wallet; needs high octane gas after that. Chugging is whatever from mentioned injectors to ign problems: needs sensor testing, connector cleaning etc, plugs/cap change etc.
Old Mar 5, 2005 | 11:24 AM
orelt's Avatar
I think i found the problem, i checked the other 3 plugs inside (1,3,5) and no. 1 looks like the culprit, i swap wire between 1 and 3 and the same thing. checked the resistance and its about 104-109 ohms, compare to no. 3 which is 14 ohms. is changing the the fuel injector the only solution, i guess i have to bite the bullet on this one.
thanks guys,
orelt
Old Mar 5, 2005 | 11:35 AM
Wiking's Avatar
Originally Posted by orelt
thanks guys,
orelt
So internetatomator 'won'... Next he will sell u the injector, new one
The solenoid gets its kick from the coil generated magnetism. If coil is half broken, it gives only half ? kick. Only way is to replace. Recheck resistance before replacement.
Old Mar 6, 2005 | 06:11 AM
mod or sell?
it sucks, but that is nissans flawed design that causes it.
let me know how many you want and let's work a deal.
lowpost99
Oct 26, 2025 06:53 PM
captchaos
Mar 15, 2016 12:18 PM
alahjahwan09
18
Sep 21, 2015 09:12 PM
ballerchris510
Sep 10, 2015 09:35 PM
I<3 A32's
Sep 10, 2015 11:07 AM
