Need Help
Old Mar 2, 2005 | 10:07 PM
vrejon101's Avatar
Need Help
Hi I am new to this forum and let me tell you it's one of the most informative one's ive ever visited. I am having a problem with my 94 Maxima GXE automatic. When I first start the car up (cold engine) it seems to idle too fast. After a while I rev the engine twice and it seems to settle down. Yesterday after work I started my car up and again it had the fast idle. This time when I put it in reverse and started to back out the engine died on me. After starting it up again I let it idle for a while then revved the engine up twice, put it in reverse and backed out quickly, this kept it from stalling out again. On the drive home I had no problems, only have problems when the engine is cold. The outside temp was in the low 60s. This is only a recent problem. What could be the problem. Any help would be greatly appreciated.
Old Mar 2, 2005 | 11:16 PM
Wiking's Avatar
You dont tell about any maintenance. Its wonder how well u engine runs...
Do the basic maintenance, check all [engine end] small hoses for brittled ends. They cause leaks... Coils brittled, clean, laquer - or replace. Cold air bypass valve jammed?
How to check IACV: http://www.cardomain.com/memberpage/748507/4
Old Mar 3, 2005 | 12:41 AM
Vadim-93GXE
When you say "idles too fast", do you mean the RPM seems a bit high?
Old Mar 3, 2005 | 05:35 AM
vrejon101's Avatar
Yes exactly. The Idle RPM seems too high
Old Mar 3, 2005 | 06:45 AM
internetautomar's Avatar
mod or sell?
RPM amount please
