Inner glo not working PLEASE HELP
Old Mar 4, 2005 | 07:05 PM
expressinme's Avatar
Ok after replaces 2 fuses that were burned out, my inner glos arent working at alll. My digital clock and my digital a/c dissapears after i turn on my headlights. A few connections are unhooked like hazard button, cig lighter, and the power comfort switch. I know when i hook up the hazard button my indicators work but nothing as for the inner glos. Please help if ya'll can.
Old Mar 4, 2005 | 07:27 PM
mtnbikeair's Avatar
Well what are your "inner glo's" hooked to power source wise?
Old Mar 4, 2005 | 10:10 PM
have no idea, just know they were working fine yesterday
Old Mar 5, 2005 | 08:09 AM
markmaxima's Avatar
indaglos
the switch that controls the indaglos probably went bad, and could be causing a short in your car, my switch went bad, i took it off and connected to my parking lights, you might want to find out where the short is before ir shorts other parts of your car.
Old Mar 5, 2005 | 04:37 PM
so u think its the switch that i put the light on is bad??
Old Mar 6, 2005 | 10:50 AM
markmaxima's Avatar
inner glo
i think it is the switch, mine went out, and the indglos wouldn't come, my friend who is good electrician, took off the swtich and connected it to the parking lights, however the indaglos only stays on blue, because i don't have the switch to change it, is the indeglos the only light out or is it your entire interior lights out, if so it could be a fuse.
Old Mar 6, 2005 | 01:51 PM
well when i turn on my innerglos my clock and digital a/c dissapear, the light will fade away to where theres nothing. i think its the switch so imma try to figure out something.
Old Mar 7, 2005 | 01:47 PM
markmaxima's Avatar
indaglo
i wish you luck
Old Mar 7, 2005 | 02:00 PM
at this point, im tired of this car
Old Mar 7, 2005 | 02:13 PM
markmaxima's Avatar
indeglo
you got to remember things are going to go, and you have to be prepared to take care of it, or you buy a new car.
Old Mar 7, 2005 | 02:30 PM
just been fustrated, the paint even done yet
Old Mar 7, 2005 | 04:46 PM
Trevmister1610's Avatar
if the other items go off then u turn them on then u may be runnig to much power of off one wire
Old Mar 7, 2005 | 07:30 PM
all i did was replace two fuses and it just started acting up
Old Mar 7, 2005 | 08:49 PM
james93gxe's Avatar
You might want to try to find out what caused those two fuses to blow. Fuses tend to blow when the load in the circuit draws more current than the fuse is rated for. I'd be looking for shorts like markmaxima mentioned.
Old Mar 10, 2005 | 08:11 PM
i changed the headlight switch today, not the problem, i guess theres a short somewhere. Can it be my door poopers even tho they have been installed about a month ago???
Old Mar 11, 2005 | 08:30 PM
notice my back door switchs for my door stopped working, maybe no ground?? gotta check that tomorrow. also got my bulbs from custommaxima.com theres a major difference, now i can see whats inside
mvm062
Nov 30, 2020 09:00 AM
kmitchel
Oct 30, 2015 10:12 AM
Maxima30
Sep 7, 2015 06:13 PM
iflexsteel
Sep 2, 2015 08:04 AM
Hailstatejig
Sep 2, 2015 06:52 AM
