advanced timing?anyone know what happened
when i step on my gas a lil..i hear this funny rattling noise..i went to my boy whos a mechanic and he told me the advanced timing is whas wrong wit the car..he said im losing power..is this true or wha..serious problem or wha..feedback guys...
peace
peace
The other possibility is that your timing chain(s) is slapping around a touch. VE engines have antiknocking sensors and will retard the timing if knocking is detected. VE's just run notoriously noisy, and generally you tend to get a lot of chain and valve train noise. Throw in the VTC's and you got a whole symphony of sounds that sound aweful, but thats just sorta the way they run -- noisy.
if you do advance timing be sure also to use higher octane gas cause if you don't, there could be knocking and your timing could get retarded and you will lose power. but that doesn't happen over night unless you got some really really really bad gas in your car.
peace
peace
I get that too..
It didn't happen all the time, I remember my car used to be quiet at one point. I am suspecting the busted Catalytic converter having something to do with it, plus I have other problems which may be causing it.. Right now though, as long as it runs, I'm happy...
Timing is supposed to be electronically controlled I think, at least that's what I was told by some mechanic... it's not like on the VGs.
The timing chain... u should take a look at it, I should too i suppose, we are running into the higher milage.. 100+ k...
Originally posted by Chris91SE
yup...the 92 - 94 SE's or the VE30DE motors have timing chains...
89-91 SE/GXE and 92-94 GXE's (VG30E motors) have timing belts
Starrider
Sep 17, 2015 07:26 AM
