Radiator Qurstion!!!
Old 05-03-2001 | 10:50 PM
wizard6161's Avatar
Radiator Question!!
ok guys...I have notice that my radiator fan is not working recently. so I wanna start checking for any problems. I want to start with the radiator relays in the relay box in front of the battery. How do you test these thing so tsee if they are working or not? cause I noticed that "rad fan 1" relay is not the factory one. so I wonder if that's the problem or not.
any help on this is appreciated.
Old 05-04-2001 | 12:43 PM
wizard6161's Avatar
ohh c'mon guys I know someone knows how to test a relay!!!
Old 05-05-2001 | 11:58 AM
maxi-freak's Avatar
Get a 9 volt battery and a couple of jumper wires.
Connect the + side to one side of the coil, and the - to the other. You should be able to see a drawing on the relay itself. 2 of the pins are for the normally open switch. Don't connect to those. And don't hold the voltage there for too long; just long enough to hear it click.
Old 05-06-2001 | 02:50 PM
wizard6161's Avatar
what does NORMALLY OPEN SWITCH means?
Old 05-06-2001 | 06:39 PM
Matt93SE's Avatar
STFU n00b!
If you don't understand the wiring, I recommend just yanking the relay out and taking it to your nissan dealer or radio shack and asking if they can check it. most car stereo shops will do this too, if they're not busy.
hcarter1112
42
07-18-2022 04:35 PM
Miket2006
03-01-2021 04:55 AM
Unclejunebug
04-02-2016 06:42 AM
jchronis2552
09-23-2015 05:57 PM
RWCreative
09-21-2015 12:01 PM
