timing belt and other replacements
Old Mar 11, 2005 | 06:03 PM
vansskaterfreek's Avatar
ok, when should the timing belt be replaced, i think it is a belt and not a chain. im not sure though. is there any other parts that should be changed around 125,000 miles??? i got no owners book with the car or anything. ohh, and i also wanna add a little horsepower to the car. what are some cheap horsepower/torque increasers?????
Old Mar 11, 2005 | 06:16 PM
Loe max's Avatar
Well what model and year do you have first? Then we can tell you if you have a belt of a chain.
Old Mar 11, 2005 | 06:30 PM
Drivin Maxima's Avatar
Well, if you have a VG then you have a belt (89-91 gxe and se and 92-94 gxe only).........I'm pretty sure that the all-data maintanence schedule for the vg says that the belt should be done at 120,000mi.
As for anything else being done at the same time, I would say other accessory belts and water pump maybe, but im not sure about that one.
As for the horsepower increasers, I cant really think of anything else other than maybe an Underdrive Pulley to put on for a lil more power while your workin in that area of the engine bay. But cheap things all around would be swiss cheese the air box maybe, and Warpspeed Y-pipes are priced pretty good and I hear they are good for a few horses.
Old Mar 11, 2005 | 07:16 PM
1991 max se maybe?
Old Mar 11, 2005 | 07:23 PM
Loe max's Avatar
The replacement interval for the VG30E engine timing belt is 60,000 miles (96,000km). If the timing belt is inspected earlier shows signs of wear or defects, the belt should be replaced at that time. The VG30E engine is an interference which means a piston will collide with a valve to either bend or break it if the timing belt breaks.
Old Mar 11, 2005 | 10:58 PM
Wiking's Avatar
1991 max se maybe?
Have u stolen it 'cause no papers?
In that case get the numbers under the hood, click log on www.autozone.com and dechipter the number series. Get 'new' license plates from junkyard.
Please do not change belt if u have chain.
Stock intake/exhaust is restricted. Also std ign setting is "retarded" 'cause people want to drive with low octane: adjust it to small boost, then u must drive with higher octane.
Check that sensors work as they should, especially KS.
Peek what VGE horses with belts, KS etc, look like:
Hondarydr
Dec 30, 2024 06:15 PM
PH98I30
19
Jun 13, 2016 02:38 PM
kenc15
Sep 25, 2015 06:38 AM
JMag90
Aug 25, 2015 09:17 AM
Maxima2010 Prem
Aug 13, 2015 11:34 AM
