super bad gas mileage
Old Mar 14, 2005 | 12:41 PM
internetautomar's Avatar
mod or sell?
just filled up my tank and I got a whopping 10.3774 MPG!
my car is bone stock, and 95% original.
I'm gonna stop by radio shack and pick up a resistor to test the knock and see if that helps my mileage (I already run 93 octane, and haven't touched my timing. I should be ok for 1 tank)
My camaro beats the crap out of this thing for mileage!
good thing summer is coming.
T-tops off, radio up. 274lbs of torque @ 2400 rpm
Old Mar 14, 2005 | 01:03 PM
kiyakerz's Avatar
you think thats bad gas mileage? my friend filled his tank up half way and someone siphened out all his gas while he was working (guess thats not really bad gas mileage, but really bad luck!)
Old Mar 14, 2005 | 01:07 PM
mod or sell?
that's sad, stealing someone's ****
Old Mar 14, 2005 | 01:38 PM
eric93SE's Avatar
Check for a hole in the gas tank
Old Mar 14, 2005 | 01:43 PM
mod or sell?
I wish, that would be an easy fix.
I used to get 13 and I was complaining then, I want 20s like my camaro did
Old Mar 14, 2005 | 01:45 PM
eric93SE's Avatar
Its called a FULL tune-up, Mister "I have all the parts I'll ever need".
Old Mar 14, 2005 | 01:54 PM
fred's Avatar
(substitute "more info" for "pictures")
Old Mar 14, 2005 | 02:06 PM
mod or sell?
air filter is about 2 months old.
plugs were still good when last checked.
only 1 injector is still original (2 new 3 remans <- probably the problem)
new CV shafts (month or so ago) along with the o2.
I'll know more next tank, I'm gonna test the knock with a bypass.
that and I won't be hammering it as bad (got 2 speeding tickets last tank ) I hope
Old Mar 14, 2005 | 02:59 PM
Jeff92se's Avatar
I'm needing a caw
O2 sensor of course.
Old Mar 14, 2005 | 03:33 PM
mod or sell?
silly already did that. gas mileage got worse, or so it appears
Old Mar 14, 2005 | 03:38 PM
eric93SE's Avatar
Check your temp sensor contacts for corossion.
Test the resistance of all injectors, personally I just replaced all of them (my idea of a tune up ).
Test transistor pack.
Old ignition coils? replace them all........(if you intend to keep your car).
Fuel filter?
Ignition timming.
MAFS is known to have bad contacts. Personally I chopped mine off and made new ones (will soon be soldering them on).
Vacuum leak?
Old Mar 14, 2005 | 03:43 PM
eric93SE's Avatar
Maxima filler-tube does not make siphoning possible, ie. not interautomarts problem.
Ahh. Mr. Interautomart, Check the small gas hose thats along with the filler neck for cracks etc. Its all the way at the bottom near the brakes.
I've been getting 21-24 mpg, depending on driving. So there is no reason you shouldn't be up there.
Old Mar 14, 2005 | 05:43 PM
mod or sell?
I haven't noticed any drips back there, nut I'll put it up in the air and take a gander
fuzzyuu's Avatar
damn dude, I thought my 21mpg (ALL freeway) was bad. Keep us posted on what you find.
Old Mar 14, 2005 | 11:42 PM
aw89maxSE's Avatar
I changed my o2 sensor and i didn't see a noticable change
.......but for some reason, probably like 34 months after I changed it, I just have started getting a little bit better at around 275mpg
Old Mar 15, 2005 | 12:33 AM
Wiking's Avatar
just filled up my tank and I got a whopping 10.3774 MPG!...
De finitely leaKing! Either from exhaust pipe [check; suspect there's one big hole in the end:]
-and/or- somewhere else t here is a Kingleak...
-and/or- u hit the mafiastation gasgauge jackpot.
=KS cannot drink THAT much.
Old Mar 15, 2005 | 05:03 AM
tripleGmax's Avatar
where did you get your o2 sensor, i would love 275 mpg!!
Old Mar 15, 2005 | 06:46 AM
mod or sell?
I'd settle for 27.5 MPG myself
Old Mar 15, 2005 | 06:47 AM
markmaxima's Avatar
you may have gotton some bad gas, try another gas station
Old Mar 15, 2005 | 06:55 AM
xnyc's Avatar
same problem as me..i get a lil less than 200 miles per tankful..if i drive all highway, i get around 280. did a major tuneup last time. doesnt seem to help. planning on doing o2 sensor soon..maybe its jsut the way we drive..
Old Mar 15, 2005 | 07:04 AM
mod or sell?
I gotta get this mileage up or this car has to go.
Gas is too expensive to keep it.
oh well, spring is almost here
Old Mar 15, 2005 | 07:11 AM
Wiking's Avatar
...Gas is too expensive...
Depends on viewpoint. Looks like u've got constant 66% discount...
Old Mar 15, 2005 | 07:17 AM
mod or sell?
If I was over there, I'd be rocking a diesel
Old Mar 15, 2005 | 07:23 AM
Wiking's Avatar
Theres a rocking yearly tax 500-1000$ (+100-200$ for all) to cool u down. Only Wi slaves Kings know what nationalissimus socialissimus EUFreedoom is like.
Old Mar 15, 2005 | 09:36 AM
daltongc's Avatar
wow, your bad mileage is depressing. I took mine out of town on a 200 mile trip Friday night for the first time. I didn't know what to expect, but was hoping for mpg in the upper 20's at least. My conditions were good, level road, no wind, mild temps. On the trip there, I drove 151.8 miles after filling up and went directly to the gas station once I arrived to get true read on the mileage. I was amazed that I couldn't get more than 4 gallons in the tank. By my calculations, that's nearly 38mpg. I was pleased.
Driving the car around the city for about 200 miles, I only averaged 20mpg, and on the way home there was a stiff crosswind, and I had the AC on. That trip averaged 27.5mpg. So, the mileage can really vary a lot with them it seems.
I'm also finding that the fuel gauge reads really wierd. For example, when it's sitting dead on the 1/2 tank mark, I can't put more than 5 gallons in. Anyone else's read like this?
Old Mar 15, 2005 | 10:05 AM
mod or sell?
I could easily deal with a small tax like that.
Diesels get 2x the mileage that gas cars do.
so that tax is easily buried by the savings on gas.
Old Mar 15, 2005 | 10:53 AM
Wiking's Avatar
Originally Posted by daltongc
...., I can't put more than 5 gallons in. Anyone else's read like this?
Filling: 1-2 gallon difference on what angle the car sits. The measured mileage is not exact. Some stations cheat u. The calc has to be average on many fillings...No way real 38mpg.
My filled tank is always at 3/4 mark. Empty has still 5-6 gal.
Interneautomator "I could easily deal with a small tax like that."
...needs 10-15k minimun per year to get even. Diesels cost more to buy, go buy new pump parts! In the end the difference is small. If u drive 50k per year, its real money
I have had half cars diesels, I love the torq. But the poor performance: any hayhathonda makes fun of u... nothanks; although newest diesels are quite fa$t... My max current condition is above 95% of all pop; thats nice. I can decide the position where I want to drive in a long line; mostly two lane roads around.
Old Mar 15, 2005 | 11:18 AM
mod or sell?
i guess things are a bit different there then in israel.
diesel in israel costs less than gas. so the cost savings are very quickly realized.
even if the price of gas and diesel were the same, the cost benefit is there.
and maintenance costs of a diesel vs a gas motor are roughly equal.
Old Mar 15, 2005 | 11:33 AM
Wiking's Avatar
Yes, the whole game is gvmt tax game: maximized! Only gvmt can know what is best for the ant worker. And what is left from left gvmt, stealerships take care: diesel part prices are what they decide... no real competition. Even aftermarket shops have pacts what to sell for maxima.
Old Mar 15, 2005 | 12:13 PM
T93Max's Avatar
that's funny and #&*@ up. that's mf must be really desperate. gas must of cost alot where he lived.
Old Mar 15, 2005 | 12:37 PM
maximapitko's Avatar
The Bulgarian Guy
I got 460 miles out of my tank this weekend
Old Mar 15, 2005 | 01:12 PM
DGruber 58's Avatar
hey I'm also having mileage problems. I filled up, but didn't notice until I got home (1-2 miles) the gauge was at 3/4. Then today its at about 1/2, even though I didn't go that far, unsure of miles put on though. I recently had to change my fuel/brake lines, but I haven't noticed any gas smells. I have cardboard under it now to see if it is leaking anything.
Any ideas?
Old Mar 15, 2005 | 01:26 PM
mod or sell?
if you're losing it that fast, you gotta have a leak.
Old Mar 15, 2005 | 01:38 PM
DGruber 58's Avatar
I forgot to mention when I filled up, the tank depressurized when I took the cap off, as well as when I just got home about an hour ago. Not positive, but I think that indicates either no or a very small leak. I plan to check it again before I start it next (after its sat a while). I hope its just a bad connection i need to tighten...
Old Mar 15, 2005 | 01:42 PM
tripleGmax's Avatar
just wondering if this is along the lines of your bad gas mileage......
i dont get great milage, but its good (no as low as 13 butnot as high as 275 lol). gotta do a check this tank to find out for sure what it is, but i get this black crap all up on my muffler. I assume its running rich, so would this account for bad gas mileage....and if so should a tune up be in order?
Old Mar 15, 2005 | 02:47 PM
The Bulgarian Guy
I would start by changing the water temp sensor. It's dirt cheap and it's a common problem.
Old Mar 15, 2005 | 04:09 PM
crazy4maxima's Avatar
21.5 mpg here
Old Mar 15, 2005 | 04:37 PM
maximamarv's Avatar
Originally Posted by crazy4maxima
21.5 mpg here
Are the VE's supposed to get better mileage than the VG's?
its weird... sometimes i will get 270'ish (17mpg) on a tank driving mostly highway (I usually drive above 80mph tho), and other times (when my foot is heavy around the city), i will get 220 (14mpg)
i gave the car a tuneup during september, my tires are at the pressure in the owners manual, I realise that there is no way in hell i am getting the 19/26 that is posted because i am using regular gas, its an old car, and i drive kinda aggressively.
my point: watch how you drive. if you keep it on power (i have a AT) and rev it to 3000-3500 rpm on most city corners and bring it over 4000 to pass people on the highways, your mileage will not be good.
Also going too fast on the hwy will hurt you also. when i am doing 85-95mph, my car is usually flirting w/ 3krpm
Old Mar 15, 2005 | 06:00 PM
mod or sell?
we'll see what happens, my knock sensor registered as non-existant when I tested for it. so I popped in a resistor for the moment and I'm running 93 octane with stock timing so I should be ok for a short term while I get the funds together to have it replaced.
hoefully that will help my mileage a bit, the car definately revs more freely now.
Old Mar 15, 2005 | 06:08 PM
Maxzilla91's Avatar
i got a whoppin' 6Km/L, i just bought an O2 sensor from internet automart and installed it, now it's going through its first tank after replacement. i'm seeing huge improvements already...
