Window peobs need help!!!!!!
Old May 5, 2001 | 07:27 AM
Deo46
I have an 89 maxima Gxe only 1 of my windows will go up and down (drivers side rear) the other 3 dont do anything. Any help on wht the problem and the fix is would be appreciated
Old May 5, 2001 | 07:52 AM
maxi-freak's Avatar
It sounds like your switch cluster on the driver's door. Pull the driver's side door panel and measure the voltage coming into the cluster. You should have battery voltage there. Also be sure you have a good ground. Then operate the switch while measuring the voltage going into the motor (at the connector on the door frame. You should have +12 and ground in one direction, and ground and +12 in the other. Those switch clusters have a problem of building up corrosion on the internal circuitry.
Old May 5, 2001 | 02:21 PM
Czar's Avatar
Before you tear apart your door, make sure that the window lock button is released and try it again. I betcha you just bumped the window lock.(hint: its the button just right of your driver's side window automatic down button) If that still doesn't work I would check for probs at that button.
REDinLV
Aug 15, 2024 12:30 AM
Fbana41
Aug 29, 2016 12:18 PM
lrb6805
Sep 24, 2015 05:03 PM
