car shakes in drive when still
Old Mar 18, 2005 | 07:47 AM
Anttron06's Avatar
my car shakes when im not moving and im in drive. it only does this in drive. anyone have any suggestions on what it might be?
Old Mar 18, 2005 | 07:51 AM
Dj Paul's Avatar
do you feel it a little bit but not that much in neutral and park? and it almost feels the same in reverse? and it goes to pretty low rpms when you switch from park to drive?
Old Mar 18, 2005 | 09:45 AM
djx82's Avatar
Same on my car
It only shakes on DRIVE when i come to a idle.. but if i step on the gas pedal.. it's quiet again.,.. no shaking.. sometimes, the RPM really goes down low when i switch from neutral to drive. They say this is the Engine and Tranny Mounts.. which are not really cheap.. so ask around and see if it really is the mounts... i guess it is...
Old Mar 18, 2005 | 09:55 AM
Dj Paul's Avatar
mine was doing this and it was just a dirty spark plug, it had carbon deposits on it. i was running my engine too hot cuz my coolant sensor was broken. i fixed the sensor and cleaned the spark plug and now its fine. if you want you can also go to a hotter spark plug, only do one number up at a time. i would at least try it out. djx im not sure of your problem though.
Old Mar 18, 2005 | 10:07 AM
92SE_Dave's Avatar
What are the idle speed in drive ? and in park/neutral ?
In neutral should be about 750, and should drop by 100-150 in drive.
If it is lower than this then perhaps you need to have the idle speed turned up.
Also a bad alternator/battery can cause voltage drop at idle which will have fuel pump run at lower speed and thus create lower fuel pressure causing artificially rough/low idle.
Old Mar 18, 2005 | 04:46 PM
Minty91GXE's Avatar
i've got the same thing and i've been looking into it for months now. no solutions yet. its not the motor mounts though, i can gaurantee you that.
tom
Old Mar 18, 2005 | 07:02 PM
aminus21's Avatar
I have the same problem on my 90 GXE. The rpm will fluctuate sometimes ar idle while in Drive. But other than that the car runs good. spark plugs are NGK coppers with only 10k on them. Fuel and air filter, along with the PCV valve is new. I checked the resistence on the fuel injectors, and they were ok. Anyone know what the problem is??
Old Mar 18, 2005 | 09:52 PM
Josh's Avatar
do you mean your whole car shakes or just the steering wheel? if its just the steering wheel i have started having the same problem this week, i think its the pcv valve because its also having trouble finding idle but i'm not sure, i also think my tranny is having issues also but i dunno if that could contribute.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Oct 27, 2015 01:29 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
yat70458
Aug 3, 2015 01:16 PM
