VE 5spd motor into VE auto car. misses under load
Old Mar 19, 2005 | 01:23 PM
rzirker's Avatar
Just had my good motor taken out of my crashed SE5spd and put into a 92 SE auto. Engine idles fine and revs OK at stop, but sputters, misses, hesitates and damn near backfires under load on the road. Still has maybe 3/4 power, but feels rough when it's pushed.
I was told the manifolds were different, but I thought I got around that problem and got the booster to work when reved.
Any ideas and help would be appreciated. The friend who did the work is at a loss for ideas.
Could someone who is able do a search for this kind of swap on the .Org?
TIA!!!!
Old Mar 19, 2005 | 01:30 PM
subs1000w's Avatar
MAF problem maybe
Old Mar 19, 2005 | 02:51 PM
eric93SE's Avatar
Unfortunatly after an engine swap, there are too many possibilities. Start with easy electrical stuff, injector resistance (there could be a pinched wire), ignition coil resistance, do a compression test (burnt valve maybe). MAFS, TPS, Temp sensor.
Old Mar 19, 2005 | 03:35 PM
rzirker's Avatar
what is TPS? and could the temp sensor have that much affect? Both fans have been running. I expected to change it out later.
Old Mar 19, 2005 | 04:15 PM
Drivin Maxima's Avatar
The TPS is the throttle position sensor. It's the sensor right on the firewall side of the throttle body with i think 4 wires leadin out of it.
Old Mar 19, 2005 | 05:12 PM
rzirker's Avatar
I have no CEL on though.
Old Mar 19, 2005 | 05:24 PM
Cliff Clavin's Avatar
Way out West
You might want to talk with Jeff. He has done a few VE swaps, but I think all were AT to MT swaps. The JDM VE engine he swapped for me was an AT. I am pretty sure everything on the engine itself is the same on MTs and ATs except the power valve for the variable intake.
If it idles OK and revs fine at a stop, it would seem that everything on the engine side is working fine. Maybe you messed up something with the tranny? Otherwise, I would guess it was a vacuum problem or something electrical, like the previous posts suggest.
Old Mar 20, 2005 | 10:46 AM
Jeff92se's Avatar
I'm needing a caw
Booster? For the VI? Which ecu are you using? Which intake manifold? Those are the only real diff IMHO. Sounds like a big vac leak or something.
Old Mar 21, 2005 | 03:06 PM
rzirker's Avatar
I'm using the 5 spd's manifold (the whole VE engine just went from one car to the other) in the VE auto SE car with the auto's ECU.
Old Mar 21, 2005 | 03:10 PM
Matt93SE's Avatar
STFU n00b!
Bad gas?
clogged injector?
how old is the gas that's been in the tank?
I had some very similar things happen to both of my cars in the last couple months.. then I realized I filled up at the same cheapo gas station near the house on both cars..
ran that gas out, dumped some injector cleaner in it and refilled with Mobil 1 93 octane.
the problem went away after about 50 miles.
Old Mar 21, 2005 | 07:42 PM
Alex_V
Agreed, when my mom still had the max a few months ago, she complained of symtoms like that, and it was just super cheap gas. I only fill up with mobil now. Besides mobil gives the best HP any way, so why both with anything else?
~Alex
AcuraLegend
Sep 22, 2015 04:22 PM
A32goldylocks
Sep 2, 2015 06:39 AM
ef9
Aug 27, 2015 10:17 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
