STEREO HELP, ive done all my reading and still have some problems!
Old Mar 28, 2005 | 10:57 PM
eventnick's Avatar
Old Mar 29, 2005 | 04:44 AM
nelledge's Avatar
"I'm just sayin'..."
Is it an SE or GXE? My SE had stock 6x9s in the rear. Four nuts on each speaker and they were out. Replaced with better 6x9s and ran new speaker wire. (amp) The previous owner of your car may have already swapped things out. Need more information about your car to help accurately.
Old Mar 29, 2005 | 05:15 AM
Michael's Avatar
Back in a 3rd Gen.
You have the non bose system. Those are the factor speaker for the non bose system. yes the speakers are actually 5.25 but the hole and mounting holes are fine for a large 6.5 (6.75).
If you want to put the 6x9 in you will have to either cut the deck (something I dont like to do) or buy a set of bose adapters from a junk yard. I have a set of adapters I could sell you if I find all the screws to them. I will email or pm you later if I do.
Another problem with cutting the holes for the speaker is sometimes the speakers will hit the trunk torsion bar. The bose bracket takes thin into account so you dont hit the bars.
I believe there is a clarion amp for the rear speakers (a single amp instead of one on each speaker like bose...also no front amp) you have to bypass. I am not 100 sure since its been a long long time since I messed with a non bose system (like 6 or 7 years).
Old Mar 29, 2005 | 09:25 AM
eventnick's Avatar
Old Mar 29, 2005 | 11:58 PM
eventnick's Avatar
Old Mar 30, 2005 | 02:17 AM
twinkle's Avatar
that would be the amp, im not 100% sure on what wires attatch to what to bypass tho
Old Mar 30, 2005 | 09:33 AM
generation3's Avatar
I'll go look in my trunk today cause I had them bypassed a while ago.
Old Mar 30, 2005 | 05:25 PM
eventnick's Avatar
Old Mar 30, 2005 | 07:19 PM
maxitech's Avatar
Check it out- I just finished a 6x9 install today, will have pics posted this weekend. Just buy some 6x9 speaker boxes, cut them to make "risers", drill some new holes and screw them down. Also, don't but crappy boxes, the wood split in two spots when putting the screws in. Then I crzy glued the **** out of the holes and screws, no problem. they look good!
Old Mar 30, 2005 | 07:46 PM
eventnick's Avatar
Old Mar 30, 2005 | 07:52 PM
maxitech's Avatar
Like I said, pics coming soon. I cut them at like 1 or 1 1/2 in. in front and 2 or 2 1/2 in. in back. I did it on my old accord a couple years ago. The magnets fit nicely in the stock speaker hole. A word of advice, have someone in the trunk and someone above to make sure screws and box line up. I did it solo, pain in the a$$!!!
Remove stock speaker covers, you'll have to remove the rear seat back to lift off the carpet on the rear deck and remove these covers.
Old Mar 30, 2005 | 08:23 PM
eventnick's Avatar
Old Mar 30, 2005 | 08:24 PM
Michael's Avatar
Back in a 3rd Gen.
well I found my brackets but it will not do you much good because I dont have the screws that hold the speakers on.
Old Mar 30, 2005 | 08:54 PM
eventnick's Avatar
Old Mar 30, 2005 | 09:10 PM
maxitech's Avatar
They protrude a little bit, but i've got them angled forward slightly, so it looks good. also slightly angled inward
Old Mar 30, 2005 | 09:17 PM
eventnick's Avatar
so did you put covers over them, or just naked speakers?
Old Mar 30, 2005 | 09:32 PM
Michael's Avatar
Back in a 3rd Gen.
Originally Posted by eventnick
do you have 1 of the screws, i can probably match the rest
yeah...shoot me an email (click my name in my sig) and I will get you some pics and such tomorrow.
Old Mar 30, 2005 | 09:34 PM
maxitech's Avatar
There new speakers, new speakers usually come their own grills.
Old Mar 31, 2005 | 12:44 PM
maxitech's Avatar
Check out my new thread for the pics.
Old Mar 31, 2005 | 12:56 PM
maxitech's Avatar
sorry, technical problems, will post asap.
Old Mar 31, 2005 | 02:04 PM
Mic360's Avatar
ok, i by passed it and figured out the wiring, courtesy of a boardmember, craig b, www.geocities.com/bracecraig/maxima/stereo.html . Thanks a ton, but i still need to get them mounted somehow. So i need some expert advice, should i (1) get the bose mounts for the back that will allow me to put in 6x9, my problem with this is the hole is still not that big, meaning some of the speaker is blocked by the metal, is this a big deal? Should i make it bigger? And if i put the bose brackets in, can i cut it at all without messing up how it mounts? (2) I dremel the metal and get some self tapping screws and mount them there (3) I finish my little wood bracket method which is gay and ghetto.
Thanks for all the help. After this im going to do a step by step write up for the non bose system, all this info on the board is great, but its all over the place.
Nick
can someone explain to me which wires i need to cut to bypass the amp cause i need to do it with my stereo. i dont understand the directions at that link.
Old Mar 31, 2005 | 02:58 PM
eventnick's Avatar
Old Mar 31, 2005 | 03:14 PM
Mic360's Avatar
oh ok i got ya i dont know why i couldnt understand it. was a long day at work heh
Old Mar 31, 2005 | 07:19 PM
eventnick's Avatar
Old Mar 31, 2005 | 08:37 PM
maxitech's Avatar
I have pics ready to post, but i'm retarded or something. I can't figure out how to post them. I think I might not have this feature enabled by a moderator. Help me figure this one out and I'll post the pics right now.
Old Apr 1, 2005 | 12:51 AM
eventnick's Avatar
Old Apr 1, 2005 | 02:17 AM
twinkle's Avatar
to post on the forum once they are hosted, type [IMG] link goes here[/IMG]
Old Apr 1, 2005 | 06:41 AM
maxitech's Avatar
[IMG][/IMG]
Hope this works
Old Apr 1, 2005 | 02:01 PM
eventnick's Avatar
Old Apr 2, 2005 | 03:09 PM
eventnick's Avatar
Old Apr 2, 2005 | 03:13 PM
Michael's Avatar
Back in a 3rd Gen.
screw it, i got tired of waiting and got antsy and stopped caring lol, i grabbed some self tapping screws a few pieces of wood for braces and i bolted those motherF@#$rs straight to the metal from the bottom through the trunk. I made the holes slightly bigger with a jig saw, and that was that. I trimmed the screws up top with a dremel and resassembled everything. It sounds awesome. Love those kappa perfects, great speakers, i reccomend them to anyone. Next will be a few subs, but we'll hold off on that till summer. Thanks for all the help guys, look for my write up in the next few days or so.
Nick
tired of waiting on who? I told you to send me an email so I could send you pics of my bose brackets and screws but I never got an email from you so I figured you werent interested.
Anyway glad you got them in there.
sctludwig
Sep 1, 2022 01:32 PM
boomerbrian
Oct 31, 2018 10:25 AM
markevans999
Sep 10, 2015 04:29 PM
nbstriker10
Sep 4, 2015 04:26 PM
sdotcarter
Sep 2, 2015 09:53 PM
