Power wire on the '93 Max
Old Apr 2, 2005 | 01:11 PM
ANDREYCAMARGO's Avatar
Hey guys,
Does any of you have an easy/safe way to run the power wire from the battery back to the amp in the trunk? I tried to run it through the firewall but by all means I couldn't.
If you have pictures or a website that shows how to do it...
I appreciate the help.
Thanks!
Old Apr 2, 2005 | 01:13 PM
AscendantMax's Avatar
a lot here ran it through the opening where the hood release cables go through the firewall. for me though...i just drilled a hole.
Old Apr 2, 2005 | 09:47 PM
Golden Ice's Avatar
I ran my amp power cable (that now runs between by 2 batteries instead) under the car, and armored all sections that would be exposed with reinforced high pressure water hose...the stuff you can't hack through with a sharp axe in less than 3 swings
Might be smarter to just take somone elses advice and run it inside the car though..you'd PROBABLY use a shorter length that way...took 25 ft for mine to fit with about 1-2 ft of slack, but it was easier for me to do it that way than fit my fat head under the dash to see what I'm doing under there.
Old Apr 3, 2005 | 11:04 AM
Tonyklem's Avatar
just drill a hole... thats what i did
Old Apr 3, 2005 | 11:21 AM
nelledge's Avatar
"I'm just sayin'..."
I made use of an existing harness entrance on the driver side. The harness has a grommet around it, so just make an incision for your power wire. To keep the grommet as a barrier, use some liquid electrical tape on the area that you have cut. This will prevent the grommet from tearing any further and act as a filler seal. Have fun... it's tight in there.
Old Apr 3, 2005 | 04:43 PM
ozzombie13's Avatar
I will eat your children
i drilled through around where the stering goes through the fire wall. took about 5 min with an air drill amd a 1/2 inch drill bit. 4ga wire nice and easy
Old Apr 3, 2005 | 06:39 PM
generation3's Avatar
What they said. Right here.
Old Apr 5, 2005 | 03:23 PM
indd's Avatar
I liked the grommet in the fender well. Take out your driver side front tire, and the plastic shroud (not sure of a better word for it) -- behind it there is a big big grommet that is probably only like 15% used up. Drill a hole, got my 4ga in no problems. You'll have to fish a tiny tiny bit through from the hood area, but if I can do it I'm sure anyone can
melteye
May 16, 2016 12:02 AM
pkfinn
Jan 3, 2016 02:55 PM
sake1bs
Sep 19, 2015 09:32 PM
Viralkill
Aug 16, 2015 05:09 PM
doobadoo
Aug 15, 2015 06:43 PM
