Engine temps are high....HELP
Old Apr 3, 2005 | 01:22 PM
mofoaka's Avatar
so my engine feels very hot, and my exhaust is hot too, i'm not sure its normal because most other cars aren't that hot when i stand right next to it. my temp gauge looks normal. but i'm worried anyways. is there anyway i can cool down my engine more?
Old Apr 3, 2005 | 01:26 PM
nelledge's Avatar
"I'm just sayin'..."
Make sure you have adequate coolant flow. You may also want to make sure you're not running too lean. That will raise eng temps, also. Is this a new problem, or recurring?
Old Apr 3, 2005 | 04:38 PM
Brad92SE's Avatar
Check your coolant level, and make sure your fans are turning on. If you run the car on a hot day just parked, the fans should turn on after a couple minutes. Aside from that, and as long as the coolant temp is halfway or less on the gauge, you should be fine. Make sure your climate control blows plenty of hot air too. With the car running and parked, the heat coming out of the vents should not cool down much, if at all.
Old Apr 3, 2005 | 04:48 PM
Akuma2001's Avatar
I have heard of a racing radiator. what will that do? Is there something I can add to my coolant in order to lower the temp?
Old Apr 3, 2005 | 08:05 PM
mofoaka's Avatar
i might not be used to the temp, i just started driving the car again after 3 years and fixed up a couple of things. the coolant level is adequate. the fans to turn on when idling its just that its very hot compared to my turbo protege 5
fastcarny
Oct 6, 2015 10:42 AM
RWCreative
Sep 21, 2015 11:01 AM
bumpypickle
Sep 20, 2015 08:22 AM
97_GXE
Sep 15, 2015 06:47 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
