BBK will this work?
BBK will this work?
http://cgi.ebay.com/ebaymotors/ws/eB...category=33563
will these rotors work, i know the calipers are the right ones. other than that.. i need brake lines and relocation bracket.. what else?
To use those rotors, you will need to mill them down a few mm then the calipers bolt to the stock location (so no brackets).
The only rotors you need brackets for are
13" cobra rotors
12.6" 2004 Maxima rotors
13" cobra rotors
So to use Jeff's kit, can you use the stock maxima calipers, and 12.4" maxima rotors? I tried reading the thread that was already involving this stuff but there were many people with different ideas/opinions and i couldnt find a straight answer.
So here is my exact question...
If i buy the 45 dollar mounting thing from Jeff, is all i need after that larger rotors? Or do i HAVE to get new calipers and brake lines?
I might be off subject but does anyone know where i can find a write up or guide line on how to install the 300z barke upgrades. The other thing is that if you go on the ebay search tool and search for the 300z brake calipers all i find is some brake lines. would the other one like the 300zx brake calipers work.
for example would these work: http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WDVW
thanks in advance
thanks in advance
Originally Posted by Jeff92se
Quick and dirty:
Jeff92se: 300z calipers + bbk brackets + 13" Cobra rotors + lines
Matt93se: 300z calipers + bbk brackets + 2k4 rotors + lines
thanks
So something like that will work then? Sorry if this is repetative and annoying, but it would sure be an expensive mistake to get the wrong thing, and i will take the chance of making others mad.
Any set of calipers from a 1990-1996 300ZX will work WITH THE EXCEPTION OF THE N/A 1990 CALIPERS, THEY ARE 26MM VS 30MM FOR ALL OTHERS. The 1990tt and 1991 calipers are more desirable because they are Aluminum (light).
The eBay page you are looking for can't be found. It may have moved, or it may no longer be available. Please try one of the options below:
* Check the Web address you entered to make sure that it's correct.
i got a question, brake lines are necessary too?? I saw the whole system that Matt had forsale it includes them so i assume so....but just wanted to clarify
edit: found some good reading here on the brakes
Yeah i fixed the ebay page, it was missing like one letter, but it works now. So if anyone knows if that specific brake will work i would be very appreciative, and Mizeree X, thanks for all your help too!
so what, are you saying that i can use stock rotors and those 300zx calipers on the car and they'll bolt right on?
13" cobra rotors
13" cobra rotors
Thats what it sounds like, and then if you want to go bigger then thats when you have to get the brackets. Thats my understanding of it.
Lol, no you can't use 300ZX calipers with stock rotors -- our stock rotors are too narrow. Please, do some searching instead of just spreading these half-truths.
Here are the 3 front BBKs for our cars (and I'm practically repeating Jeff here)
A. 300ZX (Z32) 30mm calipers, Z32 to Maxima front brakelines are required for ALL 3 KITS
- 300ZX "Kit": A + 300ZX rotors, shaved down by 2-4mm so they clear the caliper. No bracket required
- Jeff's Cobra kit: A + 13" 98 Mustang Cobra rotors, Jeff's caliper relocation bracket, and hubcentric rings for the rotors (sold by Candiman)
- Matt's 2k4 kit: A + 12.6" 2004+ Maxima rotors, and Matt's caliper relocation bracket.
Anything else is a completely custom (ie unproven) system.
You forget the really expensive kits.
Stillen (looks like a Baer kit to me), AP and Brembo all make BBKs for our cars but they cost more than most 3rd gens are worth lol.
I think he was just setting me straight referring to the 300zx calipers.
yeah I know but I am giving him a hard time by replying to this:
thanx for the info Mizeree_X, the only last question i had was where do you get the Z32 to Maxima front brakelines? From then on i will be set and good to go. I am actually going to try this out. The other question would be would the brackets that jeff is selling fit under the 2002 nissan maxima oem rims. they are 17x7. and i wanted to use those on a 92 maxima se with the whole big brake upgrade??
thank you.
thank you.
thank you.
thank you.
There are people on the org who sell them. I'll leave it up to you to find them.
Oh, and any stock Maxima wheels from 3rd-5th gen definitely won't work. I don't know about 6th gen wheels, but I am guessing they won't fit either. You need low offset + a good spoke pattern to get the Z32 calipers to fit, they are monsters.
Originally Posted by awsm66
He knows I am just messing with him.
thank you.
thank you.
Brake lines-Matt (maybe Jeff)
Fitment under 2k2 17s...NO at least not Jeff's. Matt's maybe you would have to ask but I know I have seen Jeff or others comment the Cobra kit will not work with the 2k2 17s.
Well i'be damned!!! I have o go back o nthe drawing board and look for a new pair of shoes. But thanks for all that info came in really handy. I will do what i always do and buy everything bit by bit until i have my stuff ready. I will give my self about two months i i will sure have everything ready. And i if the rear BBK goes through i will probably do that too.
I have the rear bbk brackets here and ready to go. $75 shipped. You just need this bracket and a set of 1986 300z turbo rear rotors. Plug and play.
Uses your stock calipers
If its the radius can you modify the caliper so it will fit?
MAXSE5SPD
Sep 17, 2022 04:00 AM
jerrod99_se-l
Aug 27, 2015 08:27 PM
I sell the rotors for it.
