Leaking front & rear seals
Well, both have been leaking slightly for a long time now. Not enough for a drop in oil levels, but enough to cause a noticable mess on the bottom of the car. So, a few questions...
1. Is this common?
2. How long will it be until I NEED to replace them? Do these things get bad, fast, or just hang around and annoy you?
3. How hard is it to replace? My buddy says, it's a *****. Yes?
1. Is this common?
Originally Posted by Ivan Yulaev
...So, a few questions...
1. Is this common?
1. Is this common?
- how long does it take to get from here to t here
- it? I thought u wrote 'both'? Buddy is ½ right.
Not dangerous: keeps chassis rust protection updated, no downloads needed...
Replace the front as u wish, two ? hour job.
RRear when tranny/clutch needs to be taken off. Build ? 'diapers' under tranny...
Hmm, 2 hours for front seal? Are you sure? That's not bad at all. Is that with, or without pulling the engine?
The tranny isn't leaking much at all, not enough to drip, just enough to create a bunch of dirt on the underside of the car. That one seems like it will be harder.
The seal itself is pried out with screwdriver, new pushed in. Prepare in advace some pipe to push it equally in, so u wont rip it. Moist the seal first with oil.
Check out www.autozone. com and/or bottom of page http://www.cardomain.com/memberpage/748507/1
MAXSE5SPD
Aug 23, 2015 12:06 PM
CAN-Other LF: Worn / Broken Parts
george__
Aug 18, 2015 07:06 PM
