what the ??? whats wrong with trans
Old Apr 6, 2005 | 04:22 PM
maxedout92max's Avatar
i got a 89 nissan maxima from a lady and it was sitting for like 3 yrs.. not moved and i started it up today to see if it works and when i put it in gear u have to take it to atleast 3000-3500 rpms till it will even move a little and in L AND 2 it wont move at all. the same for rev..... just say forget it and get new one or what??????????????? its an automatic.... thanks
Old Apr 6, 2005 | 04:30 PM
lalo's Avatar
if the car was sitting for 3 years i would add trany fluid. im no expert though.
Old Apr 6, 2005 | 04:31 PM
nelledge's Avatar
"I'm just sayin'..."
I had a 727 in a Dodge that I picked up for free. It had been parked for two years. I just kept shifting and revving to make the car move back and forth 5-10 ft. About 15 minutes later... walah! Presto, fixo. Not sure if the valves/clutches had 'dried out' or what, but it worked. My theory is the fluid drained out of everything and it took some priming to get the hydraulics to work again. Not a big trans guy. Anywho, spend a little time and try it out. What do you have to lose?
Edit: Transmission fluid was topped off. Car ran like a raped ape until I sold it.
Old Apr 6, 2005 | 08:10 PM
DirtyErnie's Avatar
Check fluid, drive it a bit, when they sit that long, the torque converters drain out as far as they can, and things tend to stick, too.
change the fluid while it's all at the bottom, you'll scare yourself s#!tless with the mess in the bottom of the pan (lots of stuff suspends in tranny fluid, but settles out after a year or so). My '89 bonneville sat quite a while before I got it, and i changed the fluid before we fired up the engine (had to re-build, so while we were down there fixing stuff anyways...), it was gross; so much metal and black junk down there. tranny ran perfectly (and the engine too) until it wouldn't start at -22f one morning.
user 11122324
42
Jul 18, 2022 03:35 PM
BobTX10
Oct 7, 2015 08:43 AM
hayne
Oct 5, 2015 11:53 AM
ef9
Oct 4, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
