Window electronic problems
Old Apr 10, 2005 | 04:32 PM
MrSector9's Avatar
OK the problem I am having is that my dirvers side window will no go down.. sometimes if you tap the switch it will go down a lil at a time... It goes up fine and all other windows work fine.Sometimes it will get a big kick and work perfect for a couple weeks and then for a couple days it acts foolish.
Is there an individual relay for up and down movements or is it a shared relay?? Where are the relays located for the drivers side window? Also are these relays only avaiable through the nissan dealership?
BJ White
Old Apr 10, 2005 | 09:01 PM
Drivin Maxima's Avatar
Well, since you said that it decides when it wants to work (every now and then), then I would think that the switch itself is the problem..........I had a similar problem a lil over a year ago with me passenger window workin whenever it wanted to. I picked up a switch (drivers door switch with all controls on it) form a junk yard, put it in and its been fine ever since. Good luck
Old Apr 10, 2005 | 09:09 PM
MrSector9's Avatar
I was also thinking that and since most of my letter are wore off i posted a wanted add in the forum.... Thanks
BJ white
thenewguyy
Sep 12, 2015 11:12 AM
markevans999
Sep 10, 2015 04:29 PM
ef9
Sep 5, 2015 11:18 PM
