Brake pedal goes to the floor after rebleeding. What does that mean?
I was told that some of my poor braking symptoms sounded like very old fluid. I have changed the fluid in the system yesterday. This has not made any difference at all. The old fluid had dust in it and was brown in the calipers, I got rid of it until new clear fluid showed up.
Once that was done, I could still press the pedal to the floor with the engine running. A few facts that I know for certain:
- the fluid level never changed in 5 years that I owned the car and I never had to top up.
- braking is inconsistent, sometimes it's better, sometimes worse, but generally the more I rev the engine, the better is braking power.
Should I install a MC repair kit? Should I install caliper repair kits? It sounds like two separate problems to me: one is that there is not enough boost, which is vacuum and I am leaning towards replacing a booster; and two that there is not enough pressure created in the MC or in the calipers, but if it were the calipers, I would be loosing the fluid, so it is the MC. Do I make sense at all?
Check the vacuum lines running from the booster cylinder to the intake manifold. You might have a crack somewhere.
When most mater cylinders fail they usually leak fluid, and since you did not then I'd guess its still good (but cannot say for sure). I mostly hear that the fluid actually leaks into the booster itself, so you don't see actual fluid leaking.
Are you sure you bleed the system properly? When I bleed my entire system, braking improved significantly.
Well when you say that the braking seems to get better when you rev the engine, it sounds as if the booster has a leak in it.......if this is the case hit the junk yard and pick up another one.
However, when you say that the pedal goes to the floor, it seems as if the booster would be okay. If the booster had a leak then it would be harder to apply the brake due to the lack of the assist that the booster provides. It sounds to me as if you have some bypassing goin on in the master cylinder. In other words the cup seals in the MC are bad (prolly due to the old fluid being in there scratching them up) and are letting fluid pass by them when you step on the brake, which would let the pedal fall to the floor because the MC cant build the pressure. Just my 2 cents....good luck
Originally Posted by lalo
How did you Bleed your break system?? If your pedal goes to the floor, sounds like there is air in your break system. Im no expert but I would suggest you post how you performed the bleeding for the breaks.
Also while Im thinkin of it some cars require the person bleeding the brakes to disengage a safety button on the combination or pressure differential valve. Im not sure if Maximas require this but if you bled the system without doin that then the pedal falls to the floor when done. Give the test a try if you want....good luck
this would be the correct way to bleed the break system:
Correct way
Guaranted you wont have air, but all so try adjusting the break pedal, unlikely but still a possibility.
adjusting break pedal hight
EDIT:"If the height is under these specifications, check the system for leaks, accumulation of air or damage to the components, such as: master cylinder, wheel cylinder or etc.; make the necessary repairs. " ---autozone----
Correct way
What makes you think that I do not know how to bleed the system?
I was just asking the question to see if anything I had mentioned above sounded like an obvious mistake! I did not mean to sound irritated and I am not an errogant person, sorry if it was a rude comment in any way!
Here you go! I agree, because it has a complicated system of seals and even if one or two go, but not the outermost one, there would not be enough pressure created in one or both circuits.
And Maxima does not have an equalizing valve. My old Accord'91 did have one and I removed it, thus obtaining ideally equal braking on the left and right sides. The old valve has seized and my right side had almost no braking.
Tarzan. I'm surprised you haven't just replaced the master cylinder. This is my guess. Here is a link from the stickies:
http://www1.autozone.com/servlet/UiB...3d801f5aa3.jsp
has general info about the brake system. Also if you click back it has small sections on teh ms and booster.
That's what I think I will end up doing: replace the MC with the booster. It does not make sense to spend money on an MC rebuild kit and booster separately when I can get them both for almost same money.
Negative. It tests fine, but where is the line? It does hold the vacuum for much longer than 1 minute but I still can prove that amount of braking depends on how hard I drive. It is quite low in comfort mode and much higher in power mode of AT and if I give'r a kickdown it feels like a new car's brakes.
Very odd. Cheap check. Pull the line to the booster. Remove the 1 way check valve and make sure it's still a 1 way valve. How did you check the booster if you don't know where the line is??? There is a pic in the link?
By 'line' I mean imaginary line between good and bad booster. The test procedure described above tells me to run and shut off the engine, wait 1 minute and check if I still have vacuum by depressing the brakes several times. That checks fine.
HerpDerp1919
Sep 29, 2015 02:02 PM
