Courtesy FSTB does not fit
Hello,
I recently bought a FSTB from Nissan Courtesy for my 93 GXE. The problem was it did not fit. On the passenger side (in the engine area), there was a AC metal hose in the way. After calling Courtesy, they said that a small number of Maxima (< 20%) has this problem. I ended up returning the item.
Did anyone have the same problem? Who would I buy the FSTB from to fit with my GXE.
Appreciate all pointers.
Thanks,
TP
Thanks,
TP
Same Here
The red bracket runs into my a/c hose also. They'll be getting a call from me too. I have a VE30DE motor, so I would have had to bend the bar to get it over the motor. Not a big deal there, but I'm not messing with the plumbing to the a/c for a lousy strut bar. Mine's going back too! Bye.
I just put the corner of my bar under the front wheel and bent it up.I actually just did this last weekend so it is still fresh in my mind.And the A/C hose I took a wire tie and pulled the hose back away from the bar as tight as I could...Then tied it back it touchs a little but not nearly as much as it did.
well guys, i have the same problem. my dad and i custom made a bar basically. we used the actual bar from obx, but had to basically create new mounting brackets (well, heavily modify the existing ones). it was a lot of work, and i have tons of metal filing to do, but hey it works. and now i have no clearance problems whatsoever. the ac hose isnt a problem since the mounting brackets dont reach out as far. i didnt have to bend it either. good for me my dad is a licensed welder. hehe. we took pics of the whole process and i'll have them posted in a few days.
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Pied
Sep 26, 2015 03:29 PM
