problem with sway bar mounts busting
Old Apr 17, 2005 | 07:03 PM
erniesduckie's Avatar
i have a eibach springs, gr-2s, and suspension technique sway bars. I have had the brackets break three times and my back end is messed up (never seemed right), my shop never gets it right. i was told that i should change my sway bar to addecco (just saw a adjustable one on ebay, anybody tried it? My motor mounts dont seem to be strong enough, you step on it and it gets grindy (like the axels are doing it, but the are new, i thought that maybe the shop might have used a wrong one mine is a 90 se with abs- is there a difference.) then stops (doesnt happen all the time, and i know it isnt the tranny only 30k on it). the back end feels bouncy and hops allittle. I have alot of things on here to get more power, maybe i need poly mounts and where do i get them? Other upgrades i have is uod racing rulley, jim wolf ecu, pop charger, tranny cooler (auto), denso iridium , i know i cant spell ,most everything on this car has been changed even the brakes with stainless lines and drilled rotors with two new calibers in rear ,which still are a little noisy? alittle rub? anybody have any ideals? thanks a lot.
Old Apr 17, 2005 | 07:06 PM
MrGone's Avatar
switching to an addco wont help you at all. Best bet? Buy the Blehmco links.
www.mattblehm.com
Old Apr 18, 2005 | 04:35 PM
Jeff92se's Avatar
I'm needing a caw
If you are having the shop do it, have them cut away the stock supports and ask them to add some generic thick "L" brackets. Available at any Home Depot. They won't ever break again if it's welded on right. These L brackets are 2-3 times thicker than the stock stuff.
Old Apr 18, 2005 | 07:34 PM
mattcomet82's Avatar
"switching to an addco wont help you at all. Best bet? Buy the Blehmco links."
for real.
matts95max
Apr 23, 2025 10:44 AM
wyobbagy
Jan 3, 2023 12:03 PM
asianstyle
Sep 10, 2015 11:30 AM
spidgeon
Sep 9, 2015 03:36 PM
