Jumpy Shift- Should I be worried?
Old Apr 21, 2005 | 07:52 PM
Jaybird180's Avatar
About a year ago, I had my Auto tranny replaced on my SOHC engined Maxima. The mechanic used a tranny from a 1997 model, and ensured that it would be compatible. I didn't worry about it at first because a friend suggested that it's just software. When shifting from 1st to 2nd the tranny shifts agressively enough to jump, like a hard shift. It's smooth every other gear. I also noticed that in Power mode, it revs MUCH more freely, the low end seems unobsticted (is that a real word???). Anyways, should I be worried? Recently I noticed that from Park to Drive, I have to move the lever about 1/2 shift down to get it to engage, then its fine. Anyone w/ some advice/ experience?
Old Apr 21, 2005 | 08:56 PM
Minty91GXE's Avatar
woa i've never heard of anyone using a 97 tranny in a 3rd gen. not till u anyway.
i imagine he might have been pulling you leg and just put in another 3rd gen trans. i thought the bellhouse casing were different and it wouldnt even come close to bolting up. anyway, with the shifting, sounds like the old missing shifter bushing, which is a little cheap piece of rubber that gets rotted/worn off and make the shift loose. its located under the heat shield of the catalytic converter, a new one is 1-2$. this is not exact but : you remove a cotter pin, slide a washer off, slip it on after lubing it with brake fluid of something akin to that replace washer and pin and you're done, takes about 20 min at most.
t
Old Apr 21, 2005 | 10:16 PM
subs1000w's Avatar
definitly couldnt be from a 97 max because they have a different belhousing bolt patern
maybe could be from a 97 quest van but i think they got the VE trans which proboly has diferent elctronics
the park and drive thing could be worn shifter bushing or in need of adjustment
Old Apr 22, 2005 | 09:11 AM
DanNY's Avatar
Ad·min·is·tra·tor
97? u sure it wasn't a 99 or a 2000+?
Old Apr 25, 2005 | 11:05 AM
Jaybird180's Avatar
That's what he said. He said it had 35,000 miles on a wrecked 97 Maxima. Shouldn't there be some #'s on it to ID it? Anyway, anyone know why it shifts hard from 1st to 2nd gear?
Old Apr 25, 2005 | 11:19 AM
DanNY's Avatar
Ad·min·is·tra·tor
hard shift....fluid pressure? valve body might have something funky stuck in it? check the fluid level.
or maybe...just maybe it's an entirely wrong tranny for the car?
easy way to ID if they really did a 97+ tranny on it....look under the tranny area...do you see a tranny fluid pan (metal pan..black in color...there's a dimple kinda in the middle of it...and NOT on the engine side)? if no then you didn't get a 97 tranny.
Old Apr 26, 2005 | 08:04 AM
eric93SE's Avatar
Like minty said, check to see that both shift bushings are in place, there is one at both ends of the tranny shift cable. They are NYLON.
Old Apr 26, 2005 | 08:07 AM
maxima92se's Avatar
Does the 99 or 2000+ fit?? I am not the expert on trannies. Just asking.
Old Apr 26, 2005 | 08:46 AM
95turbo gxe's Avatar
ummm I going to say nope not at all. But i hear from a guy down by the river once that the skyline tranny will bolt right up.
Old Apr 26, 2005 | 11:45 AM
eric93SE's Avatar
Is that the same guy selling Moon Shine
02PearlSE
Feb 1, 2016 12:37 AM
carid
Sep 17, 2015 05:00 AM
Jay556
Sep 12, 2015 05:50 PM
stromm
Aug 27, 2015 04:13 PM
Jcof88
Aug 3, 2015 10:43 PM
