radiator fans not kicking on
Old Apr 24, 2005 | 06:59 PM
vansskaterfreek's Avatar
ok, my car still cannot be driven yet because of my age, well i ran the car up to normal running temp, and the fans never kicked oin, evemn over normal, is this a problem, and there are supposed to be 2 fans right??? for a 1991 SE it just dont sem right for them not coming on.
Old Apr 24, 2005 | 07:11 PM
daltongc's Avatar
I've had some issues with my fans, but it was the opposite, they wouldn't ever slow down! You should be able to see if they're working okay by turning the AC on with the car idling. The fans should both come on at low-medium speed. Someone correct me if this is wrong, I've just noticed that's how mine works. My high-speed fan issue was resolved by putting in a new air cleaner, made no sense, but hey, whatever works.
Old Apr 25, 2005 | 01:44 AM
Hectic's Avatar
how did those gxe wheels get on there? yeah, do the a/c check, if they don't come on, check/clean coolant temp sensor and wires.
Old Apr 29, 2005 | 07:43 PM
the A/C is not kicking on, and i pushed in the thingy where you fill up the freon, nothing, so id say it is empty. doesnt kick in at all, just might need a charge, then it might kick in. ohh yeah, i thioought the GXE rims looked beter, nut now i am thinging the SE rims look better, anyone else think so??? i might sell them too, dunno which oines though. i like the SE rims b\c nmot many ppl have SE maximas, you see lots of GXE around me. i like to be different, but i have no money!
Old Apr 29, 2005 | 09:40 PM
Bill Brasky's Avatar
Seperated at Birth?
logical answer: kick harder.
Old Apr 30, 2005 | 09:04 AM
bvtran's Avatar
94c Big Max
i had this problem with my car for so long....it's because the ac lost all its required pressures so it turned off the compressor and fans to prevent the ac systems from self-terminating.
Old Apr 30, 2005 | 05:35 PM
GRNMAXDMON's Avatar
i had the same problem but it turned out to be the coolant temp. sensor. if u have coolant in ur system and the fans don't turn on at all when it gets to normal temp. just unplug the sensor and the fans should come on automatically. if they come on then ur coolant temp. sensor went bad.
Old May 1, 2005 | 01:35 PM
915spd's Avatar
check coolant sensor and relays. fuses aren't a bad thing to check either.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
