Tire pressure on stock 205/65/15?
Old May 11, 2001 | 01:26 PM
LAX89GXE
Trying to find out what tire pressure people are using on their 205/65/15 tires. The manufacturer's label under the arm rest says 29psi, which seems too low.
thanks
Old May 11, 2001 | 02:21 PM
MaxPower13's Avatar
I usually put in about 32 psi which works well.
Old May 11, 2001 | 04:21 PM
speednsound007's Avatar
32 all around also...
For some reason whenever I get work done on the tire (rotated, balanced, oil change, ect) they overinflate all the tires. You have to watch out for that (I check every month) because it ruined one set of tires for me just cuz some lube place f'd up my pressure.
PJ
Old May 11, 2001 | 05:38 PM
fastmax92's Avatar
i run 35 and don't really have much of a problem i find if the tires are to low i get a mushy ride and i don't really like that and i also see that maxima's wear through tires like a **** but that is what i run but it's usually your comfort and if you see the tire is wearin funny it might be time for a roto or maybe adjust the psi ...
9aj9
Apr 5, 2020 12:11 AM
BkGreen97
Apr 2, 2016 05:47 AM
cruce91
Sep 20, 2015 10:23 AM
jfl330
Sep 4, 2015 01:44 PM
