fender removal
Old Apr 30, 2005 | 06:07 PM
whitemax28's Avatar
fender removal
anybody have a write up on how to remove and replace the fender?
Old Apr 30, 2005 | 06:19 PM
mtnbikeair's Avatar
Just take a look at it, from what i remember just looking at it only a few bolts hold it on. There are two or three when you pop the hood, and then there are probably some on the underside where the plastic guards are. Take a look and if you still need help then tell us where you are getting held up at.
Old Apr 30, 2005 | 06:26 PM
twinkle's Avatar
there are like two bolts near the door hinge, i *think* they are like 14mm or maybe 12mm im not sure, and probly one under the hood, or somewhere near the front of the fender..\
Old Apr 30, 2005 | 06:29 PM
whitemax28's Avatar
would i have to remove the tire to take it out?
Old Apr 30, 2005 | 07:31 PM
maxima92se's Avatar
It would make it a lot easier but no you dont have to.
Old May 1, 2005 | 07:33 AM
Chris Gregg's Avatar
Get Off My Lawn
There are 4-5 10mm nuts holding the fender to the bumper. You need to remove the corner light by removing the phillips screw which holds it to the headlight. There is a 10mm bolt up top between the door and the fender (tight sqeeze), then there is one at the bottom if I recall and one up under the car too (would be beneath the front mudflap). There are also about 4 bolts on top the fender which are accessable by opening the hood. You also have to remove the two phillips head/bolts that secure the headlight as well. There is also a 10mm bolt below where the fender meets the front bumper, it goes to a stabilization bracket so the bumper/fender don't flop in and out when driving down the road. You should have it off in 5-10 minutes. I suggest a short well socket with narrow extension to get between the door and fender, it's a tight squeeze.
my03maxima
Jul 28, 2024 07:40 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
Garrettz459
Sep 28, 2015 02:50 PM
Sep 27, 2015 08:37 AM
