tranny question
Old May 3, 2005 | 05:26 PM
Studio718's Avatar
tranny question
How difficult is it 2 uninstall a 91 sohc tranny?
Old May 3, 2005 | 05:36 PM
91 Maxima Girl
Are you having problem? I hope not? I can't wait to get that tranny in my car and have My baby back to normal! It really stinks to drive 35mph all the time! I feel bad for driving my maxima that slow! Let us know if you need any help! You have our numbers!
Old May 3, 2005 | 05:50 PM
subs1000w's Avatar
auto or manual?
Old May 3, 2005 | 07:53 PM
Studio718's Avatar
Originally Posted by subs1000w
auto or manual?
auto, and no i havnt even touched it yet.
Old May 3, 2005 | 07:55 PM
Studio718's Avatar
I'll get you the tranny. even if I have to pay my mechanic $75 to take it off...the problem is that I get off work late, and by time I get home its already dark. You'll get it thou :P
Old May 3, 2005 | 09:24 PM
subs1000w's Avatar
heres a link on how to replace a clutch it goes over how to remove a 5spd but it would be basicly the same for an auto except (shift cable, trans coller lines, torque converter)
http://www.4dsc.com/articles/drivetr...h/clutch.shtml
Old May 4, 2005 | 06:36 AM
91 Maxima Girl
Oh I am not doubting you! You seem like a real nice person and I know you will do what it takes to get it to me! THANKS so much.
Old May 4, 2005 | 07:30 AM
Phatsta's Avatar
ask and thou shall be answered
gimme a shout if there's anything you wanna know. actually pulling the tranny is quite easy if you have a well equipped garage. the hard thing is to get it back in right. but I guess you're not..?
I've done it like... hmm... 4 times now so I'm pretty sure of how to do it
Old May 4, 2005 | 07:45 AM
Wiking's Avatar
Yes, via hearing u battles, I would qualify u as a pro....
Old May 4, 2005 | 08:04 AM
Phatsta's Avatar
hehe yeah
first time I took it down it took something like 3-4 hours. last time it took somewhat 1½ hours
as I've said before, basically what you need to do is:
remove wheels, then driveaxles and startmotor, hold the tranny up in a overhead crane while removing 4 metal holds (2 fastened in engine, 2 fastened in chassis) plus the turbine to engine bolts, then the whole thing should come down. oh, and don't forget there are 5 (I think) electrical connectors to disconnect, as well as 2 hoses going to the radiator (tranny cooling). that's about it. should be 48 bolts total.
the pin bolts (studs) in the turbine bottom that fastnes the two holds to the engine are a *****, and the inner hold mounted to the chassis closest to the cockpit is a damn nightmare, other than that it's fairly simple. just remember to support the tranny with a crane or from underneath or whatever meanwhile, or you'll be replacing the engine soon as well
Old May 4, 2005 | 08:06 AM
DARHAW-MAX's Avatar
Go to Control Panel and select Add Remove Transmissions. From there, select the transmission that you want to uninstall and click Remove. Follow the on screen prompts. When finished, reboot. At that time, your transmission will be gone. Enjoy!
Old May 4, 2005 | 08:17 AM
Phatsta's Avatar
lol
Old May 4, 2005 | 08:19 AM
Wiking's Avatar
Hey thats the 2005 Fiat Bella Bambino: Microsoft has just made a pact to provide them operating systems... what a nightmare! Soon viruses jump off from the Fiats, down on the higway. Luckily I have a firewall in my max...
Old May 4, 2005 | 10:38 AM
Phatsta's Avatar
wiking wishing again..?
talking about it, I just have to tell this joke...
the executive of general motors Richard Wagoner and Bill Gates were chatting one day. Bill said to Richard;
-'You know Richard, if the car industry and the computer industry had gone hand in hand together you would now make cars that would run hundreds of miles on a gallon of gasoline, they'd accelerate from 0-60 in a couple of milliseconds and they'd cost a tenth of what they do today.'
Richard looked at him for a while then said;
-'Yeah sure, but no one would like to crash 5 times a day!'
hehe...
anyways... I've finished my 'pulling the tranny' guide. still just text thou... no pics but what the hell, it'll tell you what needs to be done. here it is:
http://www.cardomain.com/memberpage/749143/2
good luck!
Old May 4, 2005 | 04:02 PM
Priority05's Avatar
OMG! That was a good one.
Old May 4, 2005 | 06:08 PM
Studio718's Avatar
thnx people, I've got the two motor mounts on the right side out, then the bolts that connect the tranny to the engine itself...the right drive axle is out, but the left one is a *****...I cant get it out. now the tranny itself already leans down..but its stuck to the engine...on the back of it I see like a round shiney part with teeth and some bolts..do i need 2 losen those too?
Old May 4, 2005 | 06:21 PM
subs1000w's Avatar
there are 3 bolts that hold the passinger axle to the engine mount. if you havnt removed those thats your problem.
i can get a 5speed out without removing the passinger axle but the auto might be to big
Old May 4, 2005 | 06:23 PM
twinkle's Avatar
you need to take the bolts out, and they should be all thats holding the tranny in, you can go ahead and not worry about the other axel till will come off that when it comes off the touque converter
Old May 5, 2005 | 12:12 AM
hachidori's Avatar
noobie question here do 3rd gen maxima and nissan stanza share the same tranny?
Old May 5, 2005 | 02:08 AM
Wiking's Avatar
Lots of parts are identical... front/rear folding seats fit (means chassis 'internally same'), rear shocks fit... what isn't?
VG30E Automatic uses RE4F02, might be the same, compare that number.
VE has RE4F04
Old May 5, 2005 | 07:00 AM
internetautomar's Avatar
mod or sell?
VG and KA24 use the same trans, at least internally.
Old May 6, 2005 | 08:40 AM
Phatsta's Avatar
Just follow the writeup... it tells you all you need, should be easy enough to understand once your under the car. Supprises me you say 2 mounts when there are 4? Also be careful about having the tranny lean like that, you could damage the goods or the threads. And above all, did you remove the 4 bolts to the flywheel / turbine mount? That's *really* important so you dont damage the flywheel or the tranny turbine axle. That could be the thing you're referring to as the shiney part with teeth. The flywheel as teeth that the starter uses to turn over the engine.
This tells you everything: http://www.cardomain.com/memberpage/749143/2
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
Socalstillen
Sep 26, 2015 12:01 PM
Socalstillen
Sep 20, 2015 11:46 PM
pktaske
Sep 4, 2015 08:40 AM
