Follow-up on "The Injector Killer" Vol. 16, Pt. 4, Ch. 3
Old May 6, 2005 | 08:10 PM
  #41
MrGone's Avatar
Originally Posted by antonthegrey
touche, your "answer" to my idle problem as hardly the correct one. guess which IACV is on there now that the ecu is in the correct mode?
I helped put the car back together today and it was infact the IACV you replaced, and I called it too. You owe me fi dolla.
Old May 6, 2005 | 08:22 PM
  #42
VEvolution's Avatar
I miss my VE
**The technician found the vehicle's #4 fuel injector has failed and will have to be replaced. The vehicle is NOT safe to drive at this time, as there is a danger of the engine becoming hydraulically locked.
did you get that out of an automotive school book by any chance?
btw, can that really happen to an engine if driven with a bad injector? i could have swore that i drove around with half my injectors bad for about 6 months. after replacing all injectors, engine runs like a charm
Old May 7, 2005 | 09:36 AM
  #43
92SE_Dave's Avatar
As far as I know it can easily happen while starting but is not permanent.. ie crank it again and it will break the hydraulic lock. So basically it doesn't matter just can be a bit of a pain starting once in a while.
Old May 7, 2005 | 10:43 AM
  #44
VEvolution's Avatar
I miss my VE
i don't recall having hesitation issues during start-up tho. hydraulic lock
Old May 7, 2005 | 02:59 PM
  #45
MrGone's Avatar
Ummm, you can't "break" a hydrolock, once it actually happens you are looking at a new motor.
Old May 7, 2005 | 06:06 PM
  #46
VEvolution's Avatar
I miss my VE
and driving around with bad injectors would cause this?
Old May 7, 2005 | 07:46 PM
  #47
internetautomar's Avatar
mod or sell?
95% of the time a bad injector will dump NO fuel so no hydro-lock. BUT you can damage your cylinders because the cylinders then lack the lubrication and coolant that they need to function.
Old May 7, 2005 | 08:06 PM
  #48
VEvolution's Avatar
I miss my VE
phew, 6 months of 2-3 bad injectors during constant driving for me... after replacement, engine runs great, i got the lucky then
Old May 12, 2005 | 07:37 PM
  #49
android94301's Avatar
So if I'm trying to unblock a plugged injector by using pour-in injector cleaner for a week or so, is my motor in danger or not? All the other injectors are fine.
Old May 12, 2005 | 08:25 PM
  #50
VEvolution's Avatar
I miss my VE
ouch, i read using injector cleaner will make our injectors prone to failure. dont take my word for it tho, some of the more experience members should have more to say about it.
Old May 13, 2005 | 09:57 AM
  #51
pito11213's Avatar
I remember that hydrolock due to bad injectors is dependent on if they get stuck open or closed. Hydrolock is also a danger when you change an injector and pinch the o-ring causing fuel to get into the cylinder. I have used BG cleaner from nissan and it does work pretty good.
Maxboy23
55
May 1, 2025 06:09 PM
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
msellas
Sep 23, 2015 09:16 PM
