Washed engine - chugging & idling high now
Old May 12, 2005 | 08:27 PM
shvelle's Avatar
Washed my engine bay the other day - done it many times b4 without issues - but this time it's decided to act up.
Starts fine and will not die. For a few days after washing it, it would chug and stutter while idling and driving - like I was abruptly getting on the gas, then lifting. Thought if I got it nice and warm on a long fast drive it would dry something out and problems would go away. Didn't work (tried several times now). At times it would bog - the gas pedal had NO effect whatsoever and car would decelerate on it's own.
Then the chugging and stuttering and bogging went away - only to be replaced by a high idle (2000 rpm!). So I thought disconnecting the battery would help reset the computer and whatever sensor was acting up. Didn't work - all that did was bring back the chugging and bogging and stuttering. Now, after another night of driving around, it's back to it's high-idle thing (which is actually preferential vs. the sudden bucking and bogging in city traffic) - but it's embarrassing and frustrating me to no end!
Any ideas? If I can't figure it out by Friday afternoon, it's going to the shop cause I'm just f'ing sick of it acting up on me.
Old May 12, 2005 | 09:26 PM
CyMax's Avatar
The 89' has a VG engine (?) correct? If so you might want to check out your Dist for leakage. I had a similiar problem in my Probe GT, a watery disty = unhappy engine. The chugging / high idle problem could be attributed to the emu trying to compensate for such a problem.
Old May 12, 2005 | 11:47 PM
Wiking's Avatar
TPS -pool has now toads growing bigger... take water out, and they'll dry.
Btw. GeneRally its better to keep the computer room dry!
Old May 13, 2005 | 06:32 AM
shvelle's Avatar
Yes, the '89 has a VG. However, it also has a distributor cap cover, and because I was spraying mainly from the top, and only with low pressure, the water never got under this cover. I know cause I took that cover off and it was still dusty, dirty underneath it. So I'm fairly sure it's not distributor related. All plugs are firing and all wires are fine too.
I too suspected the TPS because of the revving and the time the throttle seemed to do NOTHING. But I can't see how any water would have penetrated the casing?? I've disconnected the wiring harness and the connections were dry.
Last night I drove home from the girlfriends, and it was idling at about 2200 rpm. I pulled into my spot and turned it off after about 5 seconds just sitting there. This morning I go out and ran fine at first, then it idled up a couple times on it's own, then returned to normal. So it seems to be slowly working it's self out - but I still wanna know what's causing it.
Does our car have a limp home mode? That would explain the high idle after the chugging and stuttering. Cars just compensating.
Old May 13, 2005 | 06:41 AM
Wiking's Avatar
Originally Posted by shvelle
...Does our car have a limp home mode? ...
Yes, 2200rpm limit.
TPS is a open haystack.
see http://www.cardomain.com/memberpage/748507/6
Old May 13, 2005 | 07:05 AM
shvelle's Avatar
So are you saying I just need to take the cover off the TPS and dry it out and clean it, then seal the case? Or do I need to re-calibrate or replace the entire unit now? (electronics is NOT my forte...)
Old May 13, 2005 | 07:15 AM
Wiking's Avatar
If your problem is water in TPS, thats it. Easier is to make a hole, and flood it with cleaner, as depicted on my web page. ...Or install a blower overnight blowing against the case. Sealing is done not to get the tingie wet again...
New one is about 90$. Adjustment is only rotating the assy with loosened screws, zero pos sw has juts close when throttle off. Its all there on the webpage, and/or service manual.
Old May 13, 2005 | 07:57 AM
shvelle's Avatar
Ok thanks for the tips. Will give it a shot tomorrow. Hopefully that's the only issue.
Old May 13, 2005 | 11:15 PM
DARHAW-MAX's Avatar
Man, you keep me laughing.
Old May 13, 2005 | 11:42 PM
Wiking's Avatar
Nice to hear! Some seem to be crying for my typos, but then, nothin seem to be well in their world. ...Facts (?) are most enjoyable: the squirrel -story here is still my favorite, how the described fault evolution grew during one week until the car did not start. It was decribed as fact: Bunch of squirrels went for daily food un his/her the hood...
Old May 15, 2005 | 01:28 PM
vansskaterfreek's Avatar
if that dont work, check the oil, might be a water problem in the oil, ya never know, weird stuff always happens.
Old May 15, 2005 | 02:25 PM
Ja[M]z's Avatar
thats what i call a big signature pic
Old May 15, 2005 | 03:16 PM
goon9's Avatar
THIS ISN"T A BIG BLOCk where ya buy degreeser in the gallon and power was it. LOl... I did the same... I was driving the next day and the car shut off in traffic. The moisture snapped the engine control fuse.
Old May 21, 2005 | 05:30 AM
TommyT's Avatar
Mine occasionally does this after I drive through the car wash. Still haven't figured it out yet but it always clears up eventually.
Old May 22, 2005 | 05:55 PM
bad wires, cracked plugs???? happened to my sister in her 1988 Ford Thunderbird....
captchaos
Mar 15, 2016 12:18 PM
fastcarny
Oct 6, 2015 10:42 AM
bryants95max
Oct 2, 2015 12:52 PM
ballerchris510
Sep 10, 2015 09:35 PM
dcardello
Sep 3, 2015 11:44 PM
