speedo works up intill 22mph
Old May 14, 2005 | 12:26 PM
95turbo gxe's Avatar
hey trying to figure out whats up with my speedo it will work up intill like 22mph and then quit. then slow back down and it will work at 22mph or lower.
If they go out I thought they went out all together.
Old May 14, 2005 | 05:37 PM
rawmax1's Avatar
If you have an Automatic there should be a speed sensor going into your tranny check the connection going to it. I had the same problem before and the connector was the problem. If no auto or you have ABS it gets a bit more complicated, because you have wheel speed sensors also I believe.
Old May 14, 2005 | 06:23 PM
«§»Craig B«§»'s Avatar
ABS does have wheel sensors, but they are just to tell if the wheels are locked up or still rolling and not used at all by the speedo
could be your speed sensor or could be just that gauge
Old May 15, 2005 | 04:20 PM
rawmax1's Avatar
I know on BMW's and Porsches they have something to do with the speedo; because when the cars come in with speedo not working intermittenly it's usually one of the abs wheel speed sensors or instrument cluster. So I thought it would be the same on Maxima's. I never owned a max with ABS; but my Max without ABS did the same thing and it was the connector to the speed sensor
Old May 15, 2005 | 04:38 PM
bhunter's Avatar
Is it possible you have a problem with a space-time continuum warp and you really are just going 22 mph but it just seems faster??
Old May 17, 2005 | 01:00 PM
ahhh you got jokes
Old May 17, 2005 | 02:22 PM
lalo's Avatar
So do you suggest he check his flux-capacitor??
that would be my guess if your sped sensor is working properly.
Flux-capacitors are so hard to find now a days though
Old May 17, 2005 | 05:19 PM
mtcookson's Avatar
i would bet the wires from the speed sensor melted on your downpipe. that'd be the first thing i'd look at.
Old May 18, 2005 | 05:06 PM
done tryed it and rewired with new wires.
Old May 19, 2005 | 12:38 PM
mtcookson's Avatar
what about the other half of the wires? (from the connector towards the rest of the harness)
Old May 19, 2005 | 07:23 PM
yep got them too.
Old May 23, 2005 | 09:06 PM
mtcookson's Avatar
i'd probably try out another speed sensor and see if that helps. if you don't already have one i'm sure you can pick one up cheap at the salvage yard you've been going to. if/when you get one be sure to check the wires right next to the sensor itself. i've have one before that had one broken wire right on the sensor and you couldn't see it too well but caused some issues.
mvm062
Nov 30, 2020 09:00 AM
kmitchel
Oct 30, 2015 10:12 AM
Maxima30
Sep 7, 2015 06:13 PM
iflexsteel
Sep 2, 2015 08:04 AM
Hailstatejig
Sep 2, 2015 06:52 AM
