intermittant stalling
Old May 15, 2005 | 04:51 PM
Dummy's Avatar
im having this problem with my max, it just started happening one day and has gotten worse... itll be driving fine and then it will feel really choppy like it's missing and you can hear it in the exhaust aswell then it will just go back to normal and then back to choppy nonstop going back and forth it kinda seems like its only when you give it a certain amount of throttle but im not sure. it's kinda hard to explain so if anyone understands what i mean, do you have any idea what the problem might be?
Old May 15, 2005 | 04:59 PM
JDwyer2821's Avatar
Possible fuel pump problem. I had a stalling problem and a walbro pump fixed it
Old May 15, 2005 | 11:30 PM
Wiking's Avatar
Originally Posted by Dummy
... itll be driving fine and then it will feel really choppy like it's missing ...
Kinda million reasons. Time for tuneup...
Try reading: http://www.cardomain.com/memberpage/748507/1
Old May 16, 2005 | 01:53 AM
Dummy's Avatar
i have a walbro pump
it feels like it loses 50% of its power when it does it too it doesnt fade in or out, it feels like it's something electrical or a bad sensor or something, cut it cuts in instantly and stops instantly.
Old May 16, 2005 | 03:40 PM
Maximum Depth's Avatar
Your computer is detecting something wrong with the engine, and switching to <trouble> mode. I don't know what that mode is called, but it is serious emough that you should check it out. My Maxima acted similarly when the injector valves needed replacing. The engine code should tell you something.
Old May 16, 2005 | 04:27 PM
subs1000w's Avatar
you could try pulling codes first but if nothing comes up when was the last time you did a tuneup ie plugs wires cap rotor fuel filter etc..
if its been awhile or you dont know when they were done do that and then look into it further
after you do that if it still happens id check MAF or coil
Old May 17, 2005 | 01:48 AM
Wiking's Avatar
Originally Posted by subs1000w
...when was the last time you did a tuneup ie plugs wires cap rotor fuel filter etc..
He already answered to that question: "i have a walbro pump pump " lol
= only wimps need tuneup, just drive an wonder...
Old May 17, 2005 | 05:52 AM
'90Maxima's Avatar
I got the same problemm, it's the injector plugs try jiggling them see if it makes any diff, my mech said mine are corroded and brittle i seem to have got them in a such a position were it doen't happen anymore.. got a set of new injector wires just havn't got off my *** and replaced them.
Old May 17, 2005 | 11:22 PM
Wiking's Avatar
Dont do that if the reason is only corrosion. Why? Read the given link.
Question yall ppl: Why write and ask, but not read answers???
Old May 20, 2005 | 08:46 PM
'90Maxima's Avatar
I didn't ask a question, just trying to help.. don't do what? jiggle them? y not it works for now.
Old May 20, 2005 | 10:39 PM
Wiking's Avatar
Hmm. Me the stupido, youre right. It helps, but possibly returns. Try contact grease on pins.
Maybe connectors time is out; is there still anythin metallic left to solder wires directly? ...drill first all connector material off from injector and cut harness connector. Has to be shielded well against short circuit.
Old May 21, 2005 | 04:36 AM
TommyT's Avatar
Mine did this just before the MAF failed on me. But could be a million things.
jmlee44
Oct 2, 2022 02:13 PM
AaronL
Nov 15, 2020 11:52 AM
mikeg75
Nov 30, 2015 05:12 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
