stillen body kit
Old May 18, 2005 | 11:36 PM
3rdgene's Avatar
stillen body kit
did anyone use the hardware that came with the body kit.....i thought about using black pop rivets instead......was wondering if the hardware they sent works well or not..
Old May 20, 2005 | 08:53 AM
Chris Gregg's Avatar
Get Off My Lawn
It's fine, don't worry. It's not enough though. I had to fabricate some brackets for the rear as it wanted to sag given the distance from the tag bolts to the fender well. I crawled underneath the car and bent a peice of sheet metal in each corner of the rear of the car, attaching it to the bottom of the kit and to the bottom of the bumper of my car. Hasn't moved since. There also seems to always be an issue with the doors scraping the side skirts. Anyone figure out how to resolve this issue?
Old May 20, 2005 | 09:18 AM
swowlinc's Avatar
1993 SE
I had no problems installing my used one. With screws and 3m tape...that's all u should need.
Old May 20, 2005 | 09:51 AM
Michael's Avatar
Back in a 3rd Gen.
use good 3M tape (there are different levels of 3m tape...not the stuff from WalMart) and aluminum or stainless rivets in the fender well. I also used stainless screws above the exhaust, behind the tag and behind the fog lights in the corners because you are going into plastic and the rivet will pull through the plastic back. I have never had a problem with the good 3m tape coming off if you clean the kit and body well with wax and grease remover.
Throw the stuff that came with the kit away though. Their tape is junk and will not hold so it will come loose and sag like Chris was talking about.
t6378tp
Sep 29, 2018 04:27 PM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
Stagnet04
Sep 14, 2015 11:28 PM
Jamie Bolus
Sep 13, 2015 05:56 PM
