A few pics
Old May 22, 2005 | 09:25 PM
Jeff92se's Avatar
I'm needing a caw
A few pics
I'll try to get some more later. I'm using the stock staggared setup. I had to put the 245-45-18s in the front. haha
http://community.webshots.com/album/351324042iVJnNr
Old May 22, 2005 | 09:41 PM
usmanasif's Avatar
WOW! That looks very nice. I take it you got two sets of G35 front wheels.
Old May 22, 2005 | 09:43 PM
Jeff92se's Avatar
I'm needing a caw
That would be the easiest/cheapest but I'm running the staggered set backwards. heh
Old May 22, 2005 | 09:57 PM
Cliff Clavin's Avatar
Way out West
That looks nice.
You should have been at Shawn's today, then we could have tried them out on my car
Old May 22, 2005 | 11:01 PM
MrGone's Avatar
Originally Posted by Red92MaxSE
That looks nice.
Yeah, that would have made 4 cars and 4 Fidanzas
That looks sweet
If you dont mind I'd still love to try and test fit the cobra's on the mooostang unless your going to pull a Mizeree
those tires should be awesome in the rain
Old May 23, 2005 | 05:21 AM
Mizeree_X's Avatar
Getting back to his roots
Do it Jeff.....its so much fun being a wheel snob
Old May 23, 2005 | 06:40 AM
tripleGmax's Avatar
looks sweet. funny you had to put the 245/45 on the front. my bodywork is getting done today so i should have mine on wednesday hopefully.
i got 235/40/18 all the way around.
btw, the rims are all the same size 18x8 with 30mm offset. but the tires are staggered on the g35 the rear tires are 245/45 and the front are 225/45
Old May 23, 2005 | 07:48 AM
Jeff92se's Avatar
I'm needing a caw
yeah haven't totally decided. I'll probably sell the 17s and maybe run 300z 16 fronts for the winter. But I'd need to get my extra set of Z rotors machined down. But all it would take is to take off the brackets and I'd be good to go. It's one idea anyway
Old May 23, 2005 | 07:52 AM
Bill Brasky's Avatar
Seperated at Birth?
me likes
Old May 23, 2005 | 10:15 AM
Jeff92se's Avatar
I'm needing a caw
Heh, sorry to steal your thunder a bit man. But I've been looking for these for quite some time. Post up some installed pics asap.
I know the set is staggered though. But man, the 245s are huge compared to the 225s though. Didn't think it would make a big diff until you look at them. What tires did you get?
Old May 23, 2005 | 10:21 AM
tripleGmax's Avatar
haha no thunder stolen, we are the only two. technically mine were mounted over a week ago so i beat ya, hehe, but i had rubbin on my rear wheel well from an acident that didnt get fixed properly.
those 245s do look massive. im running kuhmo asx tires. i went for bang for buck tire that had decent reviews on tirerack. i got them local though for 560 installed.
i need tuner lugs for them still.
big props on your they look nice.
Old May 23, 2005 | 10:25 AM
CamryKilla's Avatar
lookin real good man, how much do they weigh?
Old May 23, 2005 | 10:28 AM
Jeff92se's Avatar
I'm needing a caw
The ASX are good tires from what I hear. Let me know how you like them. The guy that sold me the wheels, gave me the lugs but I ended just using my lugs I had for my other wheels. No tuner lugs needed. But I did use a Discount Tire lug wrench that has a thinner lug socket. ie.. about the thickness of a Gorilla lock socket.
Old May 23, 2005 | 10:30 AM
Jeff92se's Avatar
I'm needing a caw
They are not that light. But a bit more than my SVT 17x8 with tires. I should weigh them sometime.
Old May 23, 2005 | 11:19 AM
hadman's Avatar
Got < bish?
Old May 23, 2005 | 11:40 AM
Jeff92se's Avatar
I'm needing a caw
Nice. Subtle with just a hint of flame.
Originally Posted by hadman
Got < bish?
Old May 23, 2005 | 12:02 PM
lophix's Avatar
..no bish...but dang those things are wide..i'm scared to run anything wider than 235s. I'm surprised 235s are going on an 18" wheel though.
Old May 23, 2005 | 12:06 PM
Jeff92se's Avatar
I'm needing a caw
I ran 245-45-17s on my Cobra wheels. It rubbed very,very slightly out back. But these 245-45-18s are 4.7% larger than oem. Sorta big there. I kinda laugh when I look at the car. The 225-45-18s are about 1.7% larger than oem. Triple's 235-40-18s are right on the $, I see why he choose those. I'm going to see if a G owner wants to trade his fronts for my rears and just run teh 225-45-18s all around. Close enough for me.
Old May 23, 2005 | 12:18 PM
MrGone's Avatar
Turning radius change much?
Old May 23, 2005 | 12:21 PM
Jeff92se's Avatar
I'm needing a caw
I didn't change the steering rack
Old May 23, 2005 | 12:29 PM
MrGone's Avatar
yeah, but there should be a difference between stock 205's and 245's. I just wasn't sure if the additional height could make it worse
Old May 23, 2005 | 12:31 PM
Michael's Avatar
Back in a 3rd Gen.
looks real nice Jeff. I have loved those wheels since the first time I saw them.
Old May 23, 2005 | 12:34 PM
Jeff92se's Avatar
I'm needing a caw
Actually you are referring to width. 245 > 205. Height would be the aspect ratio with 245-45-18 being taller than the 205-65-15. I just turned the fronts lock to lock with no rubbing. But I'm not going crazy on these either. Just driving around to make sure there's not odd rubbing on dips and hard turns etc....
Old May 23, 2005 | 07:59 PM
Brad92SE's Avatar
What, were the cobra wheels too played out for you Jeff?
The G35's look really nice though! It looks like there is plenty of clearance for the Z calipers. You said you might use 300z 16's for the winter, will those clear the calipers with 300z rotors? I'm just asking because I'll be getting that setup here shortly, and I'll be needing a new set of winter wheels.
Old May 23, 2005 | 09:09 PM
lophix's Avatar
i assume they aren't, but are the 225/18s wider than the 235 17s?
Old May 23, 2005 | 10:19 PM
dmontzsta's Avatar
Ford Only.
Jeff those 245s look slick. I will stick with my 235s though.
Old May 23, 2005 | 10:25 PM
Jeff92se's Avatar
I'm needing a caw
Brad. Haha. Actually the Cobras are still one of my fav 17s. Can't beat the look, size and bbk clearance w/o spacers. If I go with the 300z 16s, I'd lose the brackets and use the 300z rotor (shaved). That should clear.
I took a few more pics while I was at the gas station. I felt like a dork taking pics there but I managed two more before the geekiness set in.
Old May 23, 2005 | 11:58 PM
MrGone's Avatar
I know where that is
dome light is on though
Old May 24, 2005 | 04:39 AM
tripleGmax's Avatar
235 = width of tire.
40 = side wall profile
18 = diameter of rim
Old May 24, 2005 | 06:41 AM
internetautomar's Avatar
mod or sell?
235 = total measurement of rubber including sidewall
40= percentage of first number that is sidewall
18 = rim diameter, not to be confused with tire diameter
Old May 24, 2005 | 11:45 AM
Jeff92se's Avatar
I'm needing a caw
You know it's Mercer Island?? Impressive.
Old May 24, 2005 | 12:38 PM
MrGone's Avatar
I thought it was the one by the stop sign
Old May 24, 2005 | 12:44 PM
Jeff92se's Avatar
I'm needing a caw
Folks, this is how shawn earns his title.
Old May 24, 2005 | 01:06 PM
Way out West
Is that the one right over yonder?
Old May 24, 2005 | 01:51 PM
MrGone's Avatar
I thought it was the second stop sign off exit xx on I-xxx
Not going to get any more specific then that
I live on the hill that goes up
then 3 more!
Are those the factory tires for a G35?
Old May 24, 2005 | 02:38 PM
Jeff92se's Avatar
I'm needing a caw
Naw I put the wrong sized tires on for the hell of it
Old May 24, 2005 | 05:00 PM
MrGone's Avatar
I didn't know if the G35 came with say Bridgestones from the factory and the PO switched to the Michelin's
Old May 30, 2005 | 08:02 PM
Jeff92se's Avatar
I'm needing a caw
naw. factory tires. The wheels that I'm getting next have Potenzas though. Will be a shame to part with these G Michelins. Anyone interested in some 18" G35 coupe wheels/tires? Triple knows. People gawk that these things. Especially with the polished calipes.
Old May 30, 2005 | 08:10 PM
tripleGmax's Avatar
man you can get probably get somewhere around 1400 for those things on ebay jeff. why are you not keeping them? what wheels are you getting? did you have any problem when you put those on with the g35s center caps? my backones wont fit at all and the front pass. side wont fit, so only one fit. do you think it would be bad to shave a bit of the cv axles that sticks out the rim?
Old May 30, 2005 | 08:16 PM
Jeff92se's Avatar
I'm needing a caw
I might do that, I don't know yet. My centercaps just pop out just a tad. I might get some othe 18s. It might take a week or two to finalize everything.
