3rd gen almost stalling
hi all. a friend of mine has a 3rd gen with a problem so i am tryin to help her fix it. anyway the problem is this. in neutral the car runs fine but a soon as u put it under load be it reverse or any of the forward gears the revs drop very low and almost stall the car. this happens everytime reguardless of the running temp of the car.
thanks for your help huys
the car has 132,000 miles on it and its a n auto 1993 model
Originally Posted by Drivin Maxima
It sounds like you have the same problem I have. Does the chugging go away after a few seconds though??? Mine does....and I changed the plugs and wires and all, thats why I think its an injector problem.
Max is loaded with electronics, and injector is just one amongst many. I suggest maintenance for ignition and then everythin else. In the end, after cleaning electrical connectors, testing sensors, self diagnostics could be useable. If still all point to injectors, replace them after giving it some kind injector -snake oil into gastank.
Check out how: http://www.cardomain.com/memberpage/748507/1
pears
Sep 18, 2015 05:25 AM
97_GXE
Sep 15, 2015 06:47 AM
