Removing rear seat (lower cushion)
Old May 25, 2005 | 10:31 AM
joojoo2915's Avatar
Okay, I've been working at this for over an hour now and I just can't get it so I figure there has got to be something I'm missing. I've looked at the autoparts guide, but all it says is to just lift up and I've tried that about 17 times now with no luck. The passenger side clip came out with little problems, the drivers side, however, is being evil. I have tried everything I can think of (using a screw driver to pry the plastic casing out, yanking on it as hard as I can, releasing it from the back, along with the less severe methods of course). To be clear, I'm looking on a way to remove the rear seat, lower cushion, driver side front clip on a 94 Maxima GXE. If anyone can help I'd really appreciate it. Thanks!
Mike
Old May 25, 2005 | 10:39 AM
DanNY's Avatar
Ad·min·is·tra·tor
if you haven't...try removing the seat back first and see if that helps any.
Old May 25, 2005 | 10:42 AM
Minty91GXE's Avatar
use something broad, strong and flat to get under the seat and try to quickly "pop" the seat locks, rather than pry - they can be extremely hard to get sometimes.
Old May 25, 2005 | 10:44 AM
gdmaxse's Avatar
just jank on it as hard as you can. the seat back is bolted in under the seat bottom so dont try to take that off without the bottom off. if you got the one side loose you should be able to get both
Old May 25, 2005 | 10:52 AM
Mizeree_X's Avatar
Getting back to his roots
Also, try and get your hands right on either side of the lock, to exert the maximum amount of force in the area it is needed. Yank harder than you think you have to, its a PITA the first time. Now my seats won't stay down, lol.
Old May 25, 2005 | 12:30 PM
Cliff Clavin's Avatar
Way out West
are you sure you got all of the bolts out? I would take the top part off, too, just to be sure you didn't miss any.
It took me all of 15-20 minutes to take the back seat and the passenger seat out of my car Friday night.
Old May 25, 2005 | 01:00 PM
maximagxe90's Avatar
basicly there are six bolts that are holding the back seat together,
two for the sides, two for the middle, one for the arm rest and the rest is clips,
Old May 25, 2005 | 01:09 PM
joojoo2915's Avatar
Thank you guys, I got it. Just took a little finnesse, and by finnesse I mean standing in the middle of the car and yanking on it as hard as I could =P
Old May 25, 2005 | 03:32 PM
AscendantMax's Avatar
it's quite hard the first few times, but it'll get easier and easier. i had to use a freaking pry bar the first time i took out my seat bottom.
Old May 25, 2005 | 04:59 PM
garbury's Avatar
well someone on here suggested using a SHOVEL to remove the seats the last time this issue came up. rofl! At least you didn't have to go to extremes...
Old May 26, 2005 | 01:42 PM
vansskaterfreek's Avatar
i just put a screwdriver betwen the 2 clip thingys and pry up, make sure it is a fairly lage screw driver, it will bend if it is small, worked for me!
Old May 26, 2005 | 01:52 PM
Hemphire's Avatar
I yanked mine so hard to get it out that I smaked my head super hard on the roof light. 2 hours later i was geting a new one from the wreaker
Old May 26, 2005 | 02:03 PM
Greeny's Avatar
¯\(°_o)/¯
Use a jack hammer....
Old May 26, 2005 | 02:07 PM
Hemphire's Avatar
The seat that is.
vingodine
45
May 21, 2016 12:46 PM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
doctorpullit
Aug 20, 2015 05:15 PM
laparka66
Aug 6, 2015 09:36 AM
