Air Conditioning
Old May 30, 2005 | 10:19 AM
geoff.doctor's Avatar
Air Conditioning
Tried it for the first time today, and realized it didn't work. The light comes on, but no cold air comes through the vents. How can I tell if I just need a recharge? Also, I have a 90 SE with a good AC system, and my new car is a 93 SE. Can I install the AC from the 90 in the 93?
Old May 30, 2005 | 10:49 AM
Wiking's Avatar
Does the AC compressor engage? Is the hose from that to cabin cooling at all. =open hood...
Couple of reasons:
IF one of the fan relays do not function, or fluid level low, No AC.
Similar box is also under VE hood...
Old May 30, 2005 | 10:57 AM
Good info, I will check the fuses and see if the compressor is engaging.
Old May 30, 2005 | 03:43 PM
vansskaterfreek's Avatar
mine is out of freon or whatever they used, is there a way that I can check for a leak????? or do i have to take it somewhere?
Old May 30, 2005 | 04:25 PM
internetautomar's Avatar
mod or sell?
do you have the tools to check for a leak?
if not, then let someone else do it for like $65
Old May 30, 2005 | 05:24 PM
Cliff Clavin's Avatar
Way out West
Once it leaks out, that often means that there is a seal bad somewhere and it will continue to leak out. Refilling it will work, but for how long, it's hard to tell. It is best to have a professional look it over and replace the worn parts.
Old May 30, 2005 | 05:36 PM
but i dont know if it leaked out or if it was just used up. there is no pressure in the line at all, and the radiator fans and the air compressor dows not click on, dam $65 seems like alot.
Old May 30, 2005 | 05:40 PM
rawmax1's Avatar
$65 is well worth it. I don't believe it just got used up. There was a leak somewhere. Professional will inject a dye and charge system and see where leak is coming from without guessing. Then tell you what needs to be replaced whether it be a line/o-ring compressor condensor etc. Just make sure you don't get a rip off a/c shop that tries to sell you everything.
Old May 30, 2005 | 05:45 PM
ok will do, thanks alot
Old May 30, 2005 | 06:00 PM
johnson's Avatar
www.tiresplus.com has a coupon that will check your A/C system for $25. And the A/C system is like the brake system, the freon just doesnt run low. If its not blowing cold air (taking heat away actually) and everything else works then you have a leak somewhere.
Old May 30, 2005 | 06:37 PM
«§»Craig B«§»'s Avatar
Yeah, like rawmax said, it wont just get used up generally - my 82 Lude has never had the A/C service and it is still pretty cold. Take it to a shop and let them take a look.
Old May 31, 2005 | 07:52 AM
mod or sell?
"freon" is not a consumable like gasoline. it's more like oil or anti-freeze in that if there's no leak, it'll always be there. however unlike oil or antifreeze, it doesn't lose it's cooling properties.
Old May 31, 2005 | 01:31 PM
aw89maxSE's Avatar
Originally Posted by Wiking
Couple of reasons:
Which fluid are you talking about?
Old May 31, 2005 | 01:44 PM
johnson's Avatar
freon
inserting 10 more characters
Old Jun 1, 2005 | 06:27 PM
This is probably a dumb question, but my FSM that came with the car does not cover anything newer than 91. I am new to all of these things, so which one is the compressor and how can I tell if it is engaging. I fealt the pipes, and they all feel warm.
Old Jun 1, 2005 | 06:30 PM
NewEngSurf's Avatar
Does anyone else find there ac compressor to be really loud. When I turn mine on its really loud like deep noise groan, i put ac compressor oil in it but it didnt do much, is my compressor gona die?
Old Jun 1, 2005 | 10:03 PM
Maxzilla91's Avatar
mine makes a deep groan when i turn it on as well.. i thought that's normal...
Old Jun 1, 2005 | 10:36 PM
xtmphan's Avatar
Miy compressor is pretty quiet (93 GXE over 105K miles).
Old Jun 1, 2005 | 11:24 PM
Wiking's Avatar
WarM pipes mean --->No cold
Engine front, left side where all belts are. Go look, smbdy hits the AC on. If nothin happens, then compressor does not engage AND pipes feel warm like any...
My Compressor is kinda noisy, me can hear ooutside as car idles. Its like the engine: noise is a good indication.
Btw. For ME, WarM pipes mean --->MORE cold
Old Jun 2, 2005 | 06:52 AM
mod or sell?
if your compressor is making noise, unfortunately it is begining to fail.
:cry: like mine
Old Jun 2, 2005 | 07:06 AM
Wiking's Avatar
:cry: like mine
Thats the desTiny fro all manmade.
Luckily ? here the gloBall warMing -hoax means colder weather. lol. Here I need A/C 2weeks per year. So the car has been junk for 20yrs before the compressor fails...
But that hoax has been very profitrable, just thinkabout only the fluid price gouging; who gets those zillions? Greenpiss at least is well oiled... http://www.junkscience.com/
Old Jun 2, 2005 | 10:29 AM
Ok, so what am I going to hear or see happen when the AC is turned on. And if nothing? Do I need a new compressor. Sorry for all the questions, but its getting pretty hot out!
Old Jun 2, 2005 | 10:51 AM
DanNY's Avatar
Ad·min·is·tra·tor
if the level of freon is at the correct level you should hear the compressor clutch cycle on and off...loud click.
you should also see a slight bubbling in the sigh glass of the reciever dryer.
then you should also feel the hose that wiking mentioned to be cold.
the compressor switch is also smart enough not to turn on if your freon level is low...so either way you have a leak somewhere.
Old Jun 2, 2005 | 11:53 AM
Wiking's Avatar
Just came from phot-o-shoppin:
1. Cold hose; insulate it to get max cold. click on
http://www.cardomain.com/ride/748507/7
Danny, is the window u mention at no.(5.) ??
Btw., both fans and their relays have also to be ok for A/C to work.
Old Jun 2, 2005 | 12:00 PM
DanNY's Avatar
Ad·min·is·tra·tor
yes...sight glass on top of #5...might need to brush off some dirt to see.
Old Jun 16, 2005 | 06:11 PM
Suya's Avatar
Does anyone know how can I refill A/C gas in my 1990 Max? Where exactly I have to add the gas? Thanks.
Old Jun 17, 2005 | 01:20 AM
Wiking's Avatar
Just read, try, the given links and u will find:
...links like this
(For detailed A/C info google "accumulator orifice tube system" or check: http://www.id-usa.com/how_to_ac.asp
http://www.id-usa.com/how_to_videos.asp)
Old Jun 17, 2005 | 07:27 AM
DanNY's Avatar
Ad·min·is·tra·tor
if you're asking then don't do it.
your 90 runs on R12 which you can't get...(i'm assuming you didn't convert)....bring it to professional and let them take care of it.
Old Jun 17, 2005 | 07:35 AM
MAXI's Avatar
R12 is not available to anybody, only to those certified (has the certification) in air conditioning. R134 is available anywhere! i.e. Target store.
Old Jun 17, 2005 | 07:49 AM
DanNY's Avatar
Ad·min·is·tra·tor
post 28...i said it wasn't available to him.
Old Jun 17, 2005 | 10:34 AM
MAXI's Avatar
yup, i agree, just emphasizing.
Old Jun 17, 2005 | 05:03 PM
Suya's Avatar
Thanks for the advise. I will go to an auto repair shop this weekend. I thought, it can be done even by a dummy like me.
Old Jun 18, 2005 | 07:44 PM
mod or sell?
parts of it can be, but there are parts that need specialized tools
Mar 12, 2020 12:06 AM
Smackasmith
Feb 1, 2016 12:40 AM
msellas
Sep 23, 2015 09:16 PM
conansriver
Sep 11, 2015 10:26 AM
lux97Max
Sep 4, 2015 05:42 PM
