92 SE flooding the engine
Old May 31, 2005 | 10:59 AM
maximapitko's Avatar
The Bulgarian Guy
Hello guys,
just bought a new maxima from a guy on the org. The car is flooding really bad up to a point of not running. I now he changed the fuel pressure regulator but the problem is still there. Has anybody experienced a similar situation with a ve? Any input/hint will be apreciated! Thank you in advance
Old May 31, 2005 | 11:41 AM
Drivin Maxima's Avatar
Originally Posted by maximapitko
Hello guys,
Im thinkin either a leaky injector, or two, thats just spillin fuel into the engine. Also it may be a faulty MAF tellin the comp to put in more fuel when it doesnt need it. Thats all I can think of right now. Good luck
Old May 31, 2005 | 12:03 PM
The Bulgarian Guy
hmmm,that sounds pretty promising since i have new injectors. I have a good maf from a vg and I've read it's the same,right?Thanks guys
Old May 31, 2005 | 12:16 PM
Wiking's Avatar
Check out those MAF pin arrangements from FSM; I guess there could be ??? a difference...
Otherwise there might be fault in the injector sealings; if it floods while ign on...
Old May 31, 2005 | 12:23 PM
The Bulgarian Guy
thank you all!
Old May 31, 2005 | 04:51 PM
internetautomar's Avatar
mod or sell?
the MAF is interchangeable on all 3rd gens
the injectors are not.
type 1 : 89-92 VG30E
type 2 : 92-99 DOHC motor
types 3 and 4: 93-94 VG30E (2 available injectors)
Old May 31, 2005 | 08:49 PM
sara92max's Avatar
I had the same problem a while back after a head gasket replacment. The O-rings on one of the injectors were leaking (not holding back the pressurized fuel in the rail)
When you change the injector O-ring`s , be sure to lube the fuel rail injector seat with a lot of vasaline, if not, the small O-ring on the tip of the injector will rip or flip up and cause the leak.
Old Jun 1, 2005 | 08:07 AM
The Bulgarian Guy
Thanks again. The car is currently at a shop and I am waiting for the verdict today. I've changed injectors in my VG a couple of times as well as other maximas. What I learned from all the experience I have on cars is that 50% of the time it's better to bring it to a shop. It's cleaner for you and saves you all the guessing for what's wrong plus al the extra parts that changed trying to solve a problem. May be I am getting old and tired of having my hands in oil...Anyways, I have never worked on the VE. I'll see what they have to say and if it's up to $200-300 to get the car running I am paying it right away...We'll see...
Old Jun 1, 2005 | 08:35 AM
Wiking's Avatar
Maybe so, BUT schemas to the MAF's are definitely different. lol.
FSM MAF pins for VE:
B C D E (A&F not connected)
E +12V Fusible Link F2 Br
D ECU26 B
C Shield, Ground
B ECU 27 W
VGE:
A B C D E (F not connected)
D ECU26 B
C Shield, Ground
B ECU 27 W
A ECU 37 G/OR (not used)
... does not matter; no schema for MAF available, top $ecret.
Edit: just checked out the wires from schema.
Old Jun 3, 2005 | 09:16 AM
bmw88rider's Avatar
Except when the shop screws it up twice. That's what happened with my maxima. I blew an injector and had to take to a local shop because I was in TN with family but lived in Chicago. All of my tools were there as well. Took them 4 days to get the problem solved and even then, it was messed up before I got back to chicago. I had to tear it all down and do it again.
Old Jun 3, 2005 | 12:58 PM
Tarzan's Avatar
MAF is simply a thermoresistor. More air blows by - cooler it is - different resistance. Should not be too hard to find the function curve and pick a similar part from digikey or a local electronic surplus store.
James92SE
142
Jan 2, 2024 09:23 AM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
