oil pan
oil pan
can anyone help me with this... i have everything off to get the oil pan off, like the front cross member, alternator, engine mounts, and i have all of the bolts off of the oil pan, and the brackets on the transmission, and i have the gasket loosened so everything wiggles, but on the transmission there is this metal plate that is holding the corner of the oil pan on... anyone know how to get this off? I will post a picture soon.
to remove the metal plate you need to remove the two studs going in to it. (the two studs at the bottom of the tranny right above where you have the jack.) To do that you take 1 nut and thread it onto the stud. Then take anothe nut and tread it in top of that one. Then take two wrenches and tighten the nuts so that they are locking together. Then use the open end of your wrench and use it to turn the first nut. The stud should begin to turn instead of the nuts. Once you remove those two studs the metal plate should fall right off. (or you can for go all of this trouble and buy a stud remover but why spend the cash in my opinion.)
So i got the oil pan off... and there was some metal shavings in there, not a whole lot but it looked like someone spilt a tiny bit of glitter in some spots... i know that that isnt good, but is it bad or is it a normal thing?
Originally Posted by Mizeree_X
Its called a magnetic drain plug.
Originally Posted by D-sta
Mike, thing is this guy loves gauges. I mean you gotta see his interior, its crazy. He has a gauge for reading practically everything, but he stated that some won't be used, they are just for show, cuz he drives a show car
You just dont give up do you? You must be a lonely lonely man...
litch
123
Jan 4, 2024 07:01 PM
05RLS2
Apr 14, 2016 11:49 AM
(thats what happened when I read that)
