Changing Vaccuum Hoses
Old Jun 4, 2005 | 08:59 PM
aminus21's Avatar
I have a rough idle problem, and have checked pretty much everything. I changed cap/rotor, wires, plugs, and ohm tested injectors. I found a crack in one of the vaccuum hoses that goes from the air intake collector to this black football-sized container under the battery (whats that for??). So next week when I have some time off, I plan on changing all the vaccuum hoses, and also cleaning the TB and IACV valve since I heard those can also cause idle problems.
I want to change all the vaccuum hoses. I think its about time, since most of them are hard, and my car is about 16 years old. What sizes are the hoses, and how much do I need? Can somone give me a rough estimate, like 3ft. of 3x8 hose, or something like that.
I have already ordered the pcv to rear crankcase hose, since that one is different sizes on each end. Thanks in advance for everybody's help..
Old Jun 5, 2005 | 04:55 AM
Wiking's Avatar
- Cold, hot or both? TPS=cold, O2=hot. Both=none of those.
- Measure MAF.
- New cap may be doa... dead on arrival.
- Check voltage at ECU. Groundings. Connectors cleanup...
Old Jun 5, 2005 | 09:05 AM
eric93SE's Avatar
If you can afford it, replace all the injectors. Even thought they have the correct resistance, they have a filter screen that gets plugged up, and their are o-rings that leak fuel into the cylinder. As a cheap way out you can remove them and clean their screens and buy a all new seals.
Old Jun 5, 2005 | 09:18 AM
aminus21's Avatar
The idle will go to like 5500rpm, and then go back up to 7000 at a stop light while in Drive. No codes at ECU, cleaned ground connectors already, and ohm tested MAF. It does this both, when the car is cold or hot. I am planning on changing the O2 sensor anyways. All the injectors were changed at 50k with OEM Nissan ones.
I remember Wiking saying that all vaccuum hoses should be changed at 100k. My car now has 98k. Is there a way that I can find out how much I need to buy? Should I get them from local parts store that sell hoses by foot, or get from Nissan?? and should I also change all those coolant hoses that go to the Air intake collector??
Old Jun 5, 2005 | 09:52 AM
Wiking's Avatar
Originally Posted by aminus21
The idle will go to like 5500rpm, and then go back up to 7000 at a stop light ...
- ECU is a lol lottery machine: first need to buy a ticket...
- There are lots too many connectors...try to find them all.
- Was that 7000/5500rpm a typo or actual? Thats not question of idle... U must mean 550...
- Ohm tested MAF? ...but did u check the gradual voltage rise?
- The need for hose replacement can be viewed: take out the engine attached (=typically hot end) hoses. View with good light, press and look for brittles. I just cut off half inch... Bend hoses and look for cracks: if found, replacement keeps towing company bankrupt.
- Do the IACV cleanup: infinidecimally small leak may cause problems. Use liquid sealant if necessary. Even installing the feed tube back may be cause a leak; it may not seat at first 100%.
- If money problems [=too much] go to stealer$hip. Or send a boatload to me and then autozone...
e-dit
Check also Nissan TSB NTB94-085.pdf; idle fluctuation due to filter.
TSB's see for http://maxima.theowensfamily.com/tsb
Old Jun 5, 2005 | 12:02 PM
eric93SE's Avatar
yeah, I hope that was a typo.
Old Jun 7, 2005 | 02:26 PM
aminus21's Avatar
yes it was a typo, my bad. i meant 700rpm down to 550.
so has anyone changed their vaccuum hoses?
Old Jun 7, 2005 | 03:19 PM
eric93SE's Avatar
Idling between 700 and 550 is very normal. You might want to bump your idle speed in park up to 800.
I've replaced all my vacuum lines a few years back, so I don't know lengths or sizes, but make sure they fit fairly tightly. They are all metric, but I don't they they are all whole numbers.
Old Jun 7, 2005 | 05:15 PM
Nickpisp's Avatar
I would guesstimate that I used about 6 ft of 3/8"
conansriver
Nov 18, 2015 02:46 PM
bumpypickle
Sep 20, 2015 08:22 AM
followthadollar
Sep 13, 2015 09:55 AM
Steven Orozco
Sep 12, 2015 10:41 PM
