turbo maxima stuff
Old Aug 2, 2005 | 05:14 PM
  #41
Alex_V
Ok I was wondering. Ill see if my buddy has anything smaller laying around then.
Im really wondering which turbos you guys used, as that would point me in a much better direction. I might end up with a turbo with the right A/R but not the best if you know what I mean.
~Alex
Old Aug 2, 2005 | 05:20 PM
  #42
mtcookson's Avatar
i still have the 300ZX "T3" and was planning on going all out with a holset hx35 but this site should help you out quite a bit: http://www.mygen.com/users/dbruce/my...sor%20Maps.htm
Old Aug 2, 2005 | 05:34 PM
  #43
Alex_V
When is full boost hitting? How about the 1-3K range, hows the boost/power there? How about higher RPMs in 3-5th? Just wondering.
~Alex
Old Aug 2, 2005 | 05:37 PM
  #44
mtcookson's Avatar
with the stock Z turbo full boost is probably around 2500 rpm. it should be quite a bit lower but my exhaust setup is all screwed up at the moment. once i fix it i should be able to spool that particular turbo without a load (which means the thing will spool very fast).
Old Aug 2, 2005 | 05:55 PM
  #45
Alex_V
Nice, If your going to get rid of it soon, lmk. Id buy it.
Or if not I think I might just go grab one for myself.
As far as manifolds,do 2ed gen or 300zx manifolds flow enough, or would custom made headers work alot better? As far as spool goes.
~Alex
Old Aug 2, 2005 | 08:30 PM
  #46
mtcookson's Avatar
i believe some Z31 guys have proven the stock Z manifolds to flow enough for 400 whp, which is damn good. the problem is you have to change some stuff around to make it all work. setting up the exhaust the way i showed in the diagram should allow for very good flow. if done right i believe it should flow better than the stock Z manifolds. i'm not positive on that but i'm pretty sure.
Old Aug 3, 2005 | 10:38 AM
  #47
maxmaxima91's Avatar
Originally Posted by Alex_V
All you turbo experts, would this be a decent match for my VG? http://cgi.ebay.com/ebaymotors/T4-Ki...QQcmdZViewItem
My buddy said it should be a good match, and since Im only going to be running 250-300HP I should be fine, as its rated to something like 400. Im just wonding if it will spool fast egnough or is it going to be a highway turbo.
If not, what turbos do you reccomend, or which ones have you guys used?
~Alex
That turbo built on a good high flow system would work very well, decent spool time and lots of top end power.... however, i would not recomend ever buying a turbo from ssautocrome, ive never heard anything but bad stuff about them . my turbo is considerably larger than that turbo (1.32 exhaust a/r) and i still hit full boost by about 3000-3500.
Old Aug 3, 2005 | 11:28 AM
  #48
mtcookson's Avatar
the big thing i'd worry about with that turbo is the large compressor. it looks like on the chart in the site i posted you'd be able to hit the numbers you want but it wouldn't even get into the compressor's high efficiency range. basically, i'd get a smaller compressor.
Old Aug 3, 2005 | 04:41 PM
  #49
Trevmister1610's Avatar
has anyone put a turbo on a automatic?
Old Aug 3, 2005 | 04:46 PM
  #50
internetautomar's Avatar
mod or sell?
nope, they're too afraid of blowing the trans.
I think aaron is planning one though
Old Aug 3, 2005 | 05:05 PM
  #51
Scope's Avatar
Im izz sexay
Built automatic not stock.
Old Aug 3, 2005 | 05:29 PM
  #52
mtcookson's Avatar
MaxO/D i believe it was was putting an awesome turbo setup in his gxe maxima. not sure if he ever finished it though.
Old Aug 3, 2005 | 06:15 PM
  #53
VEvolution's Avatar
I miss my VE
Sure they have.
http://forums.maxima.org/showthread....2&page=2&pp=30
Old Aug 3, 2005 | 10:47 PM
  #54
Originally Posted by Joe Fontinyatz
Hey... my cars not slautermatic....... . you may have mistaken the hurst shifter as an automatic, dont make fun, i like the hurst. lol
Old Aug 6, 2005 | 07:07 AM
  #55
Maxzilla91's Avatar
btw mtcookson... where do u tap the oil for the turbo on a stock vg? i saw from some sources that u have to drill into the block to get the oil flowing to ur turbo. would be best if u have a picture of where u tapped the oil from..
Old Aug 6, 2005 | 07:16 AM
  #56
mtcookson's Avatar
ahh yes, i forgot to mention that here. i have it listed on my website. you can use same spot that the Z31 turbo uses for the oil feel. it uses a banjo fitting stock so you could probably use one of those (or even modify the stock one, which is what i'm doing) or if you can find the right thread pattern setup a ss braided line.
Old Aug 6, 2005 | 08:09 AM
  #57
Maxpwer's Avatar
No turbo, no care!
Originally Posted by DanNY
well mark..i'm actually saying that you don't need to make a custom engine mount.
Old Aug 6, 2005 | 10:31 AM
  #58
gsxeclipsed's Avatar
does anyone have any pics of a set up like this?
Old Aug 7, 2005 | 05:23 AM
  #59
Scope's Avatar
Im izz sexay
www.cardomain.com/id/mtcookson
Old Aug 8, 2005 | 12:10 AM
  #60
Urbanracerh23's Avatar
thanks for the info
Old Aug 8, 2005 | 11:38 AM
  #61
camron21's Avatar
Originally Posted by pest2001
i was looking at my stock vg today and i saw that the oil filter and the coolant hose that goes to the bottom of the radiator will get in the way of the cross over. what can i do to fix that?
Yo Pest2001, your Max is hot!!!!
Old Aug 8, 2005 | 11:58 AM
  #62
camron21's Avatar
Originally Posted by mtcookson
I get a lot of emails from people asking me where to get a JDM engine but in my opinion, after having done the swap and such, that's not the way to go.
I think the best way to turbo you VG maxima would just be to use the stock engine and turbo it. Reason being, you're already starting with a 9:1 c/r engine. Its not too high and not too low. It'll spool a turbo a lot faster than a low compression VG and you'll retain the stock low end power not to mention you'll have more power at the same boost as you would a stock VG30ET simply due to the c/r being .7 higher.
Good luck to those wanting to turbo their Max!
Yo that was a lot of stuff you said my man!! I was just wondering, I'm new to the world of Mod, and stuff. Start a thread with some simple terms, and Mods and build up to the big stuff!!!!
Old Aug 8, 2005 | 08:50 PM
  #63
nismosleeper's Avatar
.....The hell???? Why don't you look around and figure out the simple stuff on your own. If you don't know the basics, then don't worry about turboing or anything else now. Find out how things work and google terms and use that newly aquired knowledge to figure out what Mark is talking about. Oh, by the way, welcome to the forums.
Ray229Harris
Sep 16, 2015 08:16 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
doobadoo
Aug 15, 2015 06:43 PM
Samedi
Aug 13, 2015 04:05 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
