Replacing lower radiator support
Old Jun 13, 2005 | 07:12 AM
nismology's Avatar
Greetings 3rd genners. I am aware that quite a few of you have had to replace your lower radiator supports for various reasons. Mine has a crack in it and i want to replace it ASAP. How'd you go about removing the old one and installing the new one? Your replies would be greatly appreciated. Thanks in advance.
Old Jun 13, 2005 | 08:10 AM
DanNY's Avatar
Ad·min·is·tra·tor
the support? like the actual metal frame of the car? or just the 2 rubber insulators?
Old Jun 13, 2005 | 08:20 AM
Jeff92se's Avatar
I'm needing a caw
The two tabs that hold the radiator up? If cracked, you will have to either cut/weld or just weld the crack up again. They aren't bolted to the car.
Old Jun 13, 2005 | 09:05 AM
nismology's Avatar
No...i mean the actual frame where the x-member bolts up...
Old Jun 13, 2005 | 09:10 AM
DanNY's Avatar
Ad·min·is·tra·tor
if its just cracked and the car is straight (not hit)...i would consider welding a patch on it and calling it a day.
Old Jun 13, 2005 | 12:26 PM
nismology's Avatar
Yea the frame isn't bent at all. What metal is it made out of so i know which type of scrap metal to look for. Thanks.
CRizz
41
Jun 7, 2021 05:42 AM
vingodine
45
May 21, 2016 12:46 PM
maxinout93
Oct 27, 2015 01:29 PM
homeyclaus
Sep 3, 2015 06:15 PM
classymax420
Aug 6, 2015 06:35 PM
