2nd Gear Scratch
Old May 17, 2001 | 11:40 PM
Jeff91SE's Avatar
My friends and I took the Max out for a little spin. I told them it was IMPOSSIBLE to get a bark out of 2nd gear. They didnt believe me. They even drove it. No 2nd gear excitement.
I used to get 2nd gear chirps whenever I wanted in my step-dads old '92 Sentra XE. Why cant I on my Max? Tires??
Is it easy for everyone else to get a 2nd gear scratch with their VG 5speed??
Old May 17, 2001 | 11:57 PM
bigjay's Avatar
i think with a y pipe and intake
or maybe just the intake if your wheels are not stock and are lighter than stock but i believe vg is only like 160ish in stock power but with a 5 speed you should be able to burnem in second and if you used to be able to do it, i recomened that you change you air and fuel filter and if they are fairly clean, it wont hurt to change your transaxle fluid and maybe even put a boost in it of some transaxle treatment off the shelf
Old May 18, 2001 | 02:23 PM
Jeff91SE's Avatar
Well the Y pipe is coming soon. But its AFTER I get the exhaust manifold studs get replaced. The CAI is AFTER the Ypipe and studs.
Maybe a tune-up wouldnt hurt. Theres no reason I shouldnt get a scratch. Maybe a short shifter wouldnt hurt either. Anyone got links or info on a short shifter??
Old May 18, 2001 | 03:02 PM
dmontzsta's Avatar
Ford Only.
I can usually always get a little chirp into 2nd when the car is cold.
Old May 18, 2001 | 06:03 PM
Jeff91SE's Avatar
Sorry, I have to poke a little fun at you here...."usually always". What does that mean??
Anyway...with all those mods you just get a chirp?
Old May 18, 2001 | 06:11 PM
dmontzsta's Avatar
Ford Only.
Usually Always...Well pretty much lets say 60% of the time I can and 40% cant.So Usually Always means pretty much all the time but sometimes I cant.And with all those mods if I had a 5 speed I could chirp everytime but I am AUTO=Did you see I mentioned shift kit...That should of said AUTO all over it.
Old May 19, 2001 | 01:25 AM
Jeff91SE's Avatar
Nope, read right over it. Like I do everything important. Actually, I just skimmed over your mods, sorry.
Old May 20, 2001 | 02:54 AM
MidnightSpeed53
question
what is a shift kit what does it do and where can i get it for is it for vg's???
thanks,
Daren
Old May 20, 2001 | 08:04 AM
lawnboy615's Avatar
I would bet anything its your clutch. Put a high performance clutch in there and you will probably chirp third.
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
knight_yyz
Nov 1, 2015 01:34 PM
Nv2dmaxmd
Oct 19, 2015 05:37 PM
